Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-25-2005, 11:17 PM   #1
C5starman
CF Senior Member
CI 7-8 Veteran
Support Corvetteforum!
C5starman's Avatar
Default Nitto 295 x 45 x 18 too tall?
I have Z06 size rear wheels (10 & 1/2"). Is the above size too tall for my 02 coupe? I ask because I did not see a 295 x 35 x 18 listed.
C5starman is offline   Reply With Quote
Old 07-26-2005, 11:23 AM   #2
Luke@tirerack
Platinum Supporting Vendor
St. Jude Donor '11
yes it is about 1.5" too tall
Luke@tirerack is offline   Reply With Quote
Old 07-26-2005, 01:45 PM   #3
Grzldvt
CF Senior Member
Grzldvt's Avatar
I am running them on a 10.5 wide wheel, and it definitely fills the well. My speedo/odo are slow(Not sure if that is really a problem ) When my speedo says 65, my GPS says I am doing 68.5. I have had no problems with them at all, but then I don't have Active Handling.
The only other problem I have found is the tall sidewall gets a bit squishy on corners when you really push the car hard.
I think I have about 5-6K on them at this point.
Grzldvt is offline   Reply With Quote
Old 07-26-2005, 07:59 PM   #4
C5starman
CF Senior Member
CI 7-8 Veteran
C5starman's Avatar
Thanks to both for the response.
Reload this Page Nitto 295 x 45 x 18 too tall?
Tags
18, 295, 45, 45x, tire, tires
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
