Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-02-2001, 12:01 PM   #1
Clink69
CF Senior Member
Clink69's Avatar
I have a 69 smallblock with those 8x15 aluminum rims from later c-3 cars. I would like to use them for now to keep the cost down. My question is what somewhat sticky tires are available currently? I am running 245x60x15s el-crapos and that seems to be the largest that will fit. I don't think 255s will behind the brake cable. What are my options with and without moving the brake cable from rear swing arm?
I found only BFG 235x60x15 drag radials available.
Any help would be appreciated.
PS: my new motor will be a 383 with around 420HP and I will need to stick much better but want mainly street driving tires.
Clink69 is offline   Reply With Quote
Old 08-03-2001, 03:41 AM   #2
jdunne
CF Senior Member
Default Re: (clink)
I have been down the same path with my74R........I gave up on trying to get decent tires in 15" sizes,put on 17" rims and couldnt be happier.....surprisingly,there are better tires in 15" for drag racing than there are in 17",so when i want to drag,I put the 15s back on......john :chevy
jdunne is offline   Reply With Quote
Old 08-14-2001, 06:07 PM   #3
Clink69
CF Senior Member
Clink69's Avatar
Default Re: (clink) Now I can't even find the BFG 235s
I would like to stick with the 15 " rims. But now I can't even find the BFG 235x60x15s. HELP! What can I use at this point? Is there any tire
that would at least be fairly decent on the street?
thanx all :smash:
Old 08-20-2001, 05:46 PM   #4
Clink69
CF Senior Member
Clink69's Avatar
Default Re: (clink) If I move the brake bracket on the rear swing arm can I fit 275x50x15s???
If I were to have the rear brake bracket moved on top of the swing arm do you think 275 x 50 x 15 s would fit with my stock alum 8 x 15 rims and no rubbin?? :cheers:
Old 08-21-2001, 11:34 PM   #5
KNEVER
CF Senior Member
KNEVER's Avatar
Default Re: (clink) If I move the brake bracket on the rear swing arm can I fit 275x50x15s??? (clink)
ttt
KNEVER is offline   Reply With Quote
Reload this Page What tires? on my 69 with 8"x15" Aluminum rims
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
