Thanks Luke.... Guess I should have done a little more research and paid attention to what I signed up for.
I was on my 2nd set of Firehawks since I replaced my OEM Goodyear EMTS at about 18K on the car through Tire Rack, and really liked everything about the Firehawks except the mileage. Only getting about 18-20K on the rears, and 30K on the fronts (Which was just about the same as the Goodyears).
I did have a concern about the Firehawks however. When my first rears were removed from the rims at about 40K on the car, there was about a 6-inch crack on the inside of both of the tires where the sidewall meets the inside bottom of the tire. I chalked it up to poor removal technique, and decided to put on another pair because I really liked the way the Firehawks performed. Well this time around (58K on the car), the same type of crack was visible on the left-rear when it was removed. This particular tire did pick up a nail about 5K ago and I had it repaired from the inside. According to my tire pressure monitor, the tire only got down to about 25psi before I had it repaired, and it did not go completely flat.
I guess my choices are:
1. Try and trade back the Michelin Pilot Sport M/Ss ZPs for non-M/S ZPs on the rear, keep the front Firehawks until they run out, and then get non-M/S Michelins on the front.
2. Try and trade back the Michelin Pilot Sport M/Ss ZPs for non-M/S ZPs on the rear, get new non-M/S Michelins on the front now.
3. Get M/Ss now on the front to replace the Firehawks.
4. Replace the new M/Ss with new Firehawks on the rear, and be wondering about the cracks being a safety issue.
What a delemma
Considering that I was happy with the Firehawks, but am now a little concerned about the cracks, and I am not happy with the handling of the Pilot Sort M/S Zps compared to the Firehawks, can you help me sort this out?
Thanks again,
Don
