Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-05-2005, 06:27 PM   #1
toolman44092
CF Senior Member
toolman44092's Avatar
Default Tires Sound Like a Truck
2003 Coupe - 15,000 miles
I've noticed over the last couple of days that my stock Good Year runflats are making much more road noise than usual at speeds of about 40 MPH and faster. It almost sounds like they're out of balance. There's a humming that seems to vibrate. I'm not sure if this means I need an alignment or if a tire went bad. Any ideas?
toolman44092 is offline   Reply With Quote
Old 07-29-2005, 09:30 AM   #2
sjc*2
CF Senior Member
sjc*2's Avatar
Default re: Tires Sound Like a Truck
According to the bulk of listers this is the downside of the runcraps. With mileage they get harder and very noisy. I am in the process of replacing my 2002 tires for non runflats. My current tires have about 20K on them and sound like studded snow tires.
The general feeling amongst the group is to shed the run flats and take the risk. Carry a tire repair kit and small compressor for those in the middle of nowhere emergencies. Lots of tire choices out there and comments on the forum.
sjc*2 is offline   Reply With Quote
Old 07-29-2005, 12:26 PM   #3
Luke@tirerack
Platinum Supporting Vendor
St. Jude Donor '11
the Goodyear runflat tires are notorious for the amount of noise they make ... it's just the tires (probably) ....
The Firestone runflats are much quieter, smoother, and offer better performance along with more tire life
Luke@tirerack is online now   Reply With Quote
Old 07-29-2005, 11:29 PM   #4
BBates
CF Senior Member
BBates's Avatar
Mine is doing the same thing without the noise. I have narrowed mine down to a bad driver front wheel bearing hub unit. I have one ordered and should be switching it out next weekend. I had the Firestone runflats and just switched to nonrunflats. The ride is totally different. Much smoother and no road noise to speak of. Good Luck, B
BBates is offline   Reply With Quote
Old 08-19-2005, 11:25 PM   #5
F16 1UB
CF Senior Member
F16 1UB's Avatar
My runcraps are at the point where you have to wear ear plugs or muffs to drowned the noise or just put the top down and crank up the Bose. 22,000 on my runcraps. Still have tons of tread remaining but don't know how much longer I'll put up with the noise. I don't drive radically just straight line acel. I even installed a sound killer 2 years ago thinking that would help. Again, refer back to top down.
F16 1UB is offline   Reply With Quote
Old 09-20-2005, 01:52 PM   #6
vermjpv
Now a Garage Queen
CI 5-6-7 & 9 Veteran
St. Jude Donor '05-'06-'07-'08
Support Corvetteforum!
vermjpv's Avatar
I could have sworn that I had bad wheel bearing. Put on new NON run flats, and it is like a new car. If it wasn't for my "sweet" sounding Corsa's, I would think I was floating on a cloud!!!!!
vermjpv is offline   Reply With Quote
Old 09-21-2005, 12:52 AM   #7
GeorgeB
CF Senior Member
GeorgeB's Avatar
I would think I was floating on a cloud!!!!! [/quote]
No joke, my new PS2s are like driving on NASA space foam
GeorgeB is offline   Reply With Quote
Old 09-30-2005, 01:18 PM   #8
cenzo
Always Learning
cenzo's Avatar
Check the inside edges of your front tires. You know, the part you never see? If they're scalloped and flat-spotted, that'll be the source of 90% of the noise. If there's lots of tread left, it might be wothwhile to remount the tires on the opposite rims so the funky part is on the outside. Get a front end alignment before you replace the tires.
__________________
Regards,
Vince
www.southernmarylandcorvetteclub.com
cenzo is offline   Reply With Quote
Old 11-04-2005, 07:59 PM   #9
rohde88
CF Senior Member
Send a message via AIM to rohde88
Quote:
Would you want to replace the tires first? The new tires will have a different height across the tire and might affect the alignment.
Ron
rohde88 is offline   Reply With Quote
Old 11-27-2005, 10:47 AM   #10
the blur
CF Senior Member
the blur's Avatar
Tires don't affect alignment.
Quote:
Ron
the blur is offline   Reply With Quote
Old 11-27-2005, 07:49 PM   #11
rws.1
CF Senior Member
rws.1's Avatar
My runcraps make more noise than my Borla exhaust...
At highway speeds I hear them.... not the Borla
I can't wait until the spring when she is back on the road with the the GoodYear GS-D3's
rws.1 is offline   Reply With Quote
Reload this Page Tires Sound Like a Truck
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
C6 run flat tires softer and rock slinging chips increase? richbell C6 Corvette General Discussion 9 11-26-2004 02:21 PM
FINALLY!! Andy gets a motor for himself!!! And it's a wild one. Andy@AandACorvette C5 Tech 34 10-27-2003 03:04 PM
600CID V-12 Engine in a C4 Light84vette C4 Tech/Performance 27 12-05-2002 11:48 PM
Tires >>> NEW POLL <<< RPO_Z06 C5 Tech 27 08-27-2001 03:55 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
