Quote:
Originally Posted by NEZO6
I have an '02 EB ZO6 lowered on the bolts with chrome wheels. Although it looks good I'm thinking about CCWs and am confused about optional wheel sizes.
If I do get larger wheels is there a reason to stay with larger rear and smaller front?
How large can I go; 19 or 20? My car is strickly street driven.
Any and all opinions would be appreciated and pictures would be great.
John
If you are interested in 19/20 you may have already read this thread:
http://forums.corvetteforum.com/show...957&forum_id=6
20s are tough to get in the right size.
Before one can answer your questions, one needs more information.
What do you mean "larger" rear "smaller" front? Diameter or width?
I assume diameter, a larger front diameter wheel will lower your tire profile and make the steering more responsive. A larger rear diameter wheel would not change the steering feel but certainly would be noticeable in any transition driving like slaloms or sudden lane changes. I would recommend that you stay with similar aspect ratios for the "looks" dept. as well as performance reasons. In other words, don't use 17s with 40 profiles in front and 19s with 30 profiles in rear.
Also when you say your car is strictly street driven, does that mean you don't accelerate hard and hot dog corners? Or do you want tires that give a good combo of street mileage/comfort and grip?
My advice is to stay away from the 20s because of the lack of tire choices. Remember, no matter how good your wheels look, you still have to drive on the tires...not the wheels! Hope this helps.
