Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-28-2005, 05:00 PM   #1
BreauxBridgeKid
CF Senior Member
BreauxBridgeKid's Avatar
Default Going with 17 x 8 all around on my 71
What size tires do I need to roll with. I cant recall the exact size the majority of our members use but it was a size with no rubbing or any unforseen problems. Thanks.
__________________
1971 Matching Numbers 350
BreauxBridgeKid is offline   Reply With Quote
Old 06-28-2005, 05:48 PM   #2
BRICHC4
CF Senior Member
BRICHC4's Avatar
check tire rack, you can look at different treads on the tires pick the exact size you want, and it will give you the price. Since most tires these days run mm dimensions and wheels in. you can figure it is about 24.5 mm per inch. on the width. The side number is an aspect ratio which is basically a percent of the hight compared to the width. If you go into specifications on the tires they will even give you overall diameter and width and the range of size wheel it will fit on. Also check out discount tire website.
BRICHC4 is offline   Reply With Quote
Reload this Page Going with 17 x 8 all around on my 71
Tags
17, 71, corvette, tires
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
C5 Z06 Frequently Asked Questions(FAQ) LTC Z06 C5 Z06 Discussion 72 11-21-2011 03:50 PM
Basic Z06 Questions from newbie MeefZ06 C5 Z06 Discussion 17 07-18-2003 08:15 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
