Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-02-2005, 01:40 PM   #1
Bolt-On
CF Member
Bolt-On's Avatar
Send a message via AIM to Bolt-On Send a message via Yahoo to Bolt-On
Default Tire direction question
Is the rear right tire tread pattern going the correct direction? There are no arrows on the sidewall indicating which direction the tire should rotate in. Any help would be appreciated. The tire is a Michelin Pilot SX.
Bolt-On is offline   Reply With Quote
Old 06-02-2005, 03:54 PM   #2
Luke@tirerack
Platinum Supporting Vendor
St. Jude Donor '11
it is a symetrical tire ... not direction, meaning you can mount them any way you want
Luke@tirerack is online now   Reply With Quote
Old 06-02-2005, 06:37 PM   #3
Bolt-On
CF Member
Bolt-On's Avatar
Cool! Thanks Luke!
Old 06-03-2005, 06:37 PM   #4
rocco16
CF Senior Member
rocco16's Avatar
Location: SCMR Rat Pack'r Charter Member..Great Bend KS
That wasn't Luke, that was an imposter.
Luke would never have misspelled "directional".
YOUR TIRES ARE ON BACKWARD!! Only drive your Corvette in reverse until this is corrected!! You risk overheating your battery if you continue to drive normally!! You may have already irreversably ruined your tires!! Have them checked by an tire pro at Salvador's Tire-'Rama immediately!! He will advise you on which used tire you should replace those bad French tires with. Road Hugger's are the tire of choice at Salvador's Tire-'Rama!
JK
Larry
code5coupe
rocco16 is offline   Reply With Quote
Old 06-04-2005, 09:32 PM   #5
Bolt-On
CF Member
Bolt-On's Avatar
I can't stop laughing!
Reload this Page Tire direction question
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Tire rotation question???? USARMYTTT C5 General 23 12-27-2004 10:03 PM
Tire inflator question? quimbo C5 Tech 9 01-17-2003 04:10 PM
Tire size and physics... Tom Steele C5 Tech 66 08-12-2002 02:44 PM
Solo 2 Tire Pressure Question - h rocks? NavyVet Autocrossing & Roadracing 13 10-17-2001 09:36 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
