06-08-2005, 11:01 AM
CF Senior Member
Some early C4 wheels made by Enkei may fit in the rear. Those wheels were found only on the Z51 or Z52 cars. The offset on the early wheels is 38mm and the new wheels are around 56mm. That difference will cause the wheel to stick out around 3/4" there could be some interference between the tire and the lip of the wheel opening once tires are installed.
A better choice would be a pair from an 88 or later C4. They will have a better offset (56mm) and be 9.5x17 in size. You should be able to find a pair fairly cheap on eBay or in the C4 Parts For Sale section. You can alsosellyour wheels there or look for a swap.
