Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ Photo AlbumsGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-10-2005, 12:25 PM   #1
92PoloVette
CF Senior Member
CI 6-7-8-9 Veteran
92PoloVette's Avatar
Default Tire Pressure, I know it's been beat to death
But can anyone shed any light on what my pressures should be? I just put on 4 new 275/40 17 inch Goodyear GSD-3 's. I have heard so many opinions on this subject, I would like some advice from some folks running the same tire as me. Sorry for asking this question again, I know it has been discussed before, but I just couldn't get a straight answer from the search I did! Any help would be appreciated.
92PoloVette is offline   Reply With Quote
Old 05-10-2005, 10:28 PM   #2
RCK1999
CF Senior Member
RCK1999's Avatar
30 lbs. cold all around.
RCK1999 is offline   Reply With Quote
Old 05-11-2005, 12:11 AM   #3
shurite44
CF Senior Member
shurite44's Avatar
Send a message via Yahoo to shurite44
You should run the recommended tire pressure that is normally posted on the door sticker regardless of the what tire you run. Pressures posted on the tire are max pressure ratings.
shurite44 is offline   Reply With Quote
Old 05-30-2005, 05:43 PM   #4
RubyDropTop
CF Senior Member
I agree. While I don't run your tire (I have Yokohama AVS Sports) I do run 30 lbs. on all 4 corners cold.
Quote:
RubyDropTop is offline   Reply With Quote
Old 06-01-2005, 01:05 PM   #5
FFIN90
CF Senior Member
CI 6-7-8-9-10 Veteran
St. Jude Donor '08-'09-'10
Support Corvetteforum!
1998 Chevrolet Corvette
FFIN90's Avatar
Location: ================ From a Fire Hall in Toronto ================ 9/11/01 FDNY 343 R.I.P.
Send a message via MSN to FFIN90 Send a message via Yahoo to FFIN90
I too have the same question. The shop that put my GSD3's on said to run them at 30-32lbs. I just had the alignment checked yesterday and the guy told me to run them at 45lbs . I left the shop and all the sensors starting giving High Pressure errors. He said I'll get better tire wear with the higher pressure.
FFIN90 is offline   Reply With Quote
Old 06-01-2005, 01:19 PM   #6
shurite44
CF Senior Member
shurite44's Avatar
Quote:
Your tire shop is correct. The alignment shop is incorrect.
Old 06-01-2005, 03:10 PM   #7
FFIN90
CF Senior Member
FFIN90's Avatar
Quote:
Thank you. 30-32 it is then, which is what I was running anyway before the alignment guy cranked them up
Old 06-03-2005, 10:05 PM   #8
Kevin21
CF Senior Member
Kevin21's Avatar
In the Arizona heat I run 28 lbs. They get up to around 32 after just a few miles.
Kevin21 is offline   Reply With Quote
Reload this Page Tire Pressure, I know it's been beat to death
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertise Here - Contact Us - Corvette Enthusiast Discussion Forum - Archive - Top
Powered by vBulletin
Search Engine Friendly URLs by vBSEO 3.3.2
