Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-08-2005, 10:25 PM   #1
stangin4lyfe
CF Senior Member
stangin4lyfe's Avatar
Send a message via AIM to stangin4lyfe
Default Please help with a tire balance problem
I just purchased a brand new set of chrome motorsport wheels from houseofwheels(Bob). As soon as I got these wheels, I had them put on.
One problem, the steering wheel shakes(like the wheels are out of balance, the steering wheel shakes, not in the rear of my seat). So I figure that it must be the balance. Here is where another problem arises, the wheels are already balanced from before. So I go to another shop and put the wheels on a different balance machine, and guess what? The wheels are balanced. I then proceeded to hit the highway, and accelerate to 65. The wheel then begins shaking back and forth.
My question is...
How do I solve this?
Does anyone have any idea's to help me?
The wheels did look symetrical.
I have hit nothing, and the wheels are brand new.
I used the same tires and I have done nothing to the car since the old z06 wheels were taken off(they rode perfect).
Nothing is wrong with the car.
I put the stock z06's back on and the car rode perfect, so obviously, it's the wheels, I just wonder how I can fix the shaking.
One more thing that adds mystery to the story, the wheel shaking comes and goes!
Sometimes it will shake profusely, then at other times it will not shake a bit, all of this at 65+ mph.
Please help.
Justin
stangin4lyfe is offline   Reply With Quote
Old 05-08-2005, 10:31 PM   #2
c4cruiser
CF Senior Member
Support Corvetteforum!
c4cruiser's Avatar
You may have a wheel that is not true (wobbles) or there is something that is keeping the wheel mounting flange from sitting flush on the hub.
The tire shop can easily spin the wheel/tore combination and check for lateral runout.
c4cruiser is offline   Reply With Quote
Old 05-09-2005, 12:09 AM   #3
ZOsix
CF Senior Member
ZOsix's Avatar
the 2 locking clips that gm uses to hold the rotor on during assembly.could it be possible they could be making your wheel not to fit true against the hub?
Maybe
ZOsix is offline   Reply With Quote
Old 05-09-2005, 01:01 AM   #4
stangin4lyfe
CF Senior Member
well the wheels are made to where you can keep those locking clips on the rotors.
Old 05-09-2005, 01:43 AM   #5
MUKAK
CF Senior Member
its not the wheels, it the tires.
I had the same problems with my KUMHO MXs, they tend to flat spot after sitting for 8 hours or so, but as soon as they warm up Shaking will go away.
I went with different tires (mich PS) and they shaking is gone!!!
I did balance the wheel and tires and 3 different shop (all were using ROAD FORCE MICHINE TO BALANCE THEM ) but they were still go OUT OF BALANCE!!!
MUKAK is offline   Reply With Quote
Old 05-09-2005, 08:41 AM   #6
stangin4lyfe
CF Senior Member
That is very strange and does not make sense because...
The tires worked fine the day before or should I say, the hour before the wheel change.
I did reuse the tires that were on the car.
They worked fine on the previous wheels.
Like I said it comes and goes, and there isn't a factor involved that determines how bad the wheel shakes, because I have sped up, slowed down, and tried just about everything, but cannot figure out what is causing the wheel to shake.
Old 05-09-2005, 11:10 AM   #7
Luke@tirerack
Platinum Supporting Vendor
St. Jude Donor '11
remove the stud clips because not all wheels are made with the recess for them
Luke@tirerack is offline   Reply With Quote
Old 05-09-2005, 12:48 PM   #8
stangin4lyfe
CF Senior Member
These wheels are.
I made sure to check for the indentions.
They are made by www.factoryreproductions.com
Would they still need to be removed?
Justin
Old 05-10-2005, 08:55 AM   #9
Luke@tirerack
St. Jude Donor '11
remove them they serve no purpose at this time and it eliminates 1 possible source of your problem
then follow this flow chart to find your problem
Reload this Page Please help with a tire balance problem
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Weights, measurements, ratios, strengths, etc leaftye C5 General 239 01-18-2012 04:29 PM
c5 coupes typically leaky? LSUgoTIGER C5 General 24 09-07-2005 11:24 PM
HELP! Road Force Balance Didn't jdbxyz C4 Tech/Performance 11 05-12-2005 10:48 PM
Car vibration at 80 mph? What is going on? Please help? tire balance? thomasguy6 C4 ZR-1 Discussion 12 03-11-2004 08:01 AM
Slotted and Drilled 12" rotors from Napa with lifetime warrenty NOT-MEE C4 Tech/Performance 57 12-30-2003 04:51 PM
Help with balancing problem wheels JCAIRE2 C4 Tech/Performance 12 03-29-2003 06:42 PM
I wish I could say I had a good transaction with red5 but I got HOSED!! BAMAGOLFER C5 Parts for Sale/Wanted 61 03-18-2003 02:00 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
