Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ Photo AlbumsGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-06-2005, 10:06 AM   #1
hz900
CF Senior Member
1990 Chevrolet Corvette
hz900's Avatar
Default What's the difference in these tire sizes?
What's the difference in these two tire sizes?
295/35/18
295/30/18
This would be mounted on a 18x10.5 on a C4 (originally 17" rims)
hz900 is offline   Reply With Quote
Old 05-06-2005, 11:46 AM   #2
MYCoupe
CF Senior Member
MYCoupe's Avatar
They have the same width (295mm), but different aspect ratios so one will be taller than the other. I would recommend that you go with the 295/35/18 size. That is what I'm using on my '94 with no problems. By the way just in case you wanted to know the 295/35 will have a dimeter of 26.1" and the 295/30 will have a diameter of 25.0". Your stock tires were probably closer to 26" diameter hence my recommendation.
__________________
MYCoupe is offline   Reply With Quote
Old 05-06-2005, 01:44 PM   #3
hz900
CF Senior Member
hz900's Avatar
Quote:
Thanks thats what I was wanting to know. I knew the 35 was the stock size, but was looking at a set of cheap 30's and didn't know what the difference was.
Old 05-06-2005, 04:45 PM   #4
MYCoupe
CF Senior Member
MYCoupe's Avatar
Quote:
No problem. Are you also going to use Z06 wheels? One thing I would change if I could do it over would be to use 18s up front as well instead of the 17s.
Old 05-30-2005, 05:49 PM   #5
RubyDropTop
CF Senior Member
Just to add....the 295/35 tire measurement means that the sidewall on that tire in 35% of the 295mm width. The 295/30 measurement means that the sidewall on that tire is 30% of the 295mm width.
RubyDropTop is offline   Reply With Quote
Reload this Page What's the difference in these tire sizes?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Nail surprise jcorsetty C6 Corvette General Discussion 10 08-07-2005 11:34 PM
What's the best wheel combination all 18's or all 17's? Gary2KC5 Autocrossing & Roadracing 25 01-02-2004 01:26 PM
Tire size and physics... Tom Steele C5 Tech 66 08-12-2002 01:44 PM
Tire Selection Hell ......I can't believe how hard this is BikerDuude C5 Tech 24 04-03-2002 07:07 PM
Advertise Here - Contact Us - Corvette Enthusiast Discussion Forum - Archive - Top
Powered by vBulletin
Search Engine Friendly URLs by vBSEO 3.3.2
