Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-28-2005, 04:23 PM   #1
JLMonaco
CF Member
Send a message via AIM to JLMonaco
Default Tire Pressure Sensor Question
I think the answer to this question is obvious...but want to be sure. I've purchased a set of Mallett XMS wheels....18X11 rear and 18X10.5 in the front....can I use my existing sensors? I'm thinking the rears will work...but will the stock sensors on my 17" fronts expand to fit my 18" Malletts?
If not...where can I get two 18" sensors?
Any help is greatly appreciated!
JLMonaco is offline   Reply With Quote
Old 04-28-2005, 04:25 PM   #2
RPOZ4Z
CF Senior Member
Cruise-In VII Veteran
RPOZ4Z's Avatar
your sensors will fit your new wheels.
the sensor is part of the valve stem.
do a search on tire pressure sensors and you should find a picture somewhere.
RPOZ4Z is offline   Reply With Quote
Old 04-29-2005, 11:22 AM   #3
JLMonaco
CF Member
Sweet...thank you....I had a different picture in my head about it....
Old 04-30-2005, 01:41 AM   #4
wamara
CF Senior Member
Cruise-In II Veteran
wamara's Avatar
JL,
The sensors are all the same size, regardless of whether they came from a 17" or 18" wheel. They may or may not work on your wheel in the OEM configuration depending on the shape of the rim/lip of your wheel. Unless you hear it from someone with past experience with this wheel, you'll just have to experiment. If the sensor won't fit in the "valve stem" hole in the wheel, you can still use it but you will have to affix it to the rim with a band clamp and/or epoxy.
wamara is offline   Reply With Quote
Reload this Page Tire Pressure Sensor Question
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Tire Pressure Sensor Question cruzin' C5 Tech 10 02-28-2002 12:48 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
