Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-23-2005, 10:08 AM   #1
MattW_VA
CF Senior Member
St. Jude Donor '07
MattW_VA's Avatar
Default Need C6 track wheels!!
Sorry if this has been covered, a quick search didn't find anything relevant.
I have a 2005 C6, Z51 (larger front rotors!) I need track wheels for! I considered buying someones stock takeoffs-but I don't want to wait around for the 19" R compound tires.
I don't suppose the T1 17" setup works on a C6?
Any suggestions would be most welcome.
MattW_VA is offline   Reply With Quote
Old 02-23-2005, 11:20 AM   #2
elh0102
CF Senior Member
I'm in the same situation, and very little is available right now. John at CCW said they will have their 18" three-piece wheel in the correct C6 offsets within a month or so. And Hickock is also supposed to have something very soon. Fiske and HRE have 18" C6 wheels, but they are very expensive. 17" wheels will work, but you will need to convert to C5 rotors and caliper brackets in front. This may be necessary anyway unless some replacement rotors are available soon in the Z51 size. Actually, it would be cheaper to convert and buy aftermarket C5 rotors, than to buy just the replacement OEM rotors from GM. Plus, you would have the option of getting rid of the drilled rotors.
elh0102 is offline   Reply With Quote
Old 02-23-2005, 11:35 AM   #3
MattW_VA
CF Senior Member
St. Jude Donor '07
MattW_VA's Avatar
Very good points on the brakes-I know c5 rotors are very affordable!
Is that the way the C6 T1 crowd is going?
Reload this Page Need C6 track wheels!!
Tags
c6, rotors, track
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Track tire/tire pressure sensor issue quick04Z06 C6 Tech/Performance 78 10-01-2011 10:31 AM
C6 Z06 Frequently Asked Questions(FAQ) LTC Z06 C6 Z06 Discussion 56 08-02-2011 03:23 PM
what 18" wheels can be used on the C6 for race rubber? RedHotBolt Autocrossing & Roadracing 33 08-22-2005 01:43 AM
Need Tire Pressure Sensor 101 for track use jmess C6 Tech/Performance 12 07-01-2005 09:53 PM
Track Wheels and Tire Pressure Sensors GentleBen C6 Tech/Performance 23 03-27-2005 04:23 PM
2003/C6 Rumors Doughan C6 Corvette General Discussion 39 07-21-2004 04:56 PM
GM photo of C6 track testing H82BFST C6 Corvette General Discussion 67 08-15-2003 04:11 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
