Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-17-2005, 10:54 PM   #1
ByByBMW
CF Senior Member
St. Jude Donor '06-'08-'10-'11
Support Corvetteforum!
ByByBMW's Avatar
Default Recommendations for 18's F & R ?
Looks like I am going to 18" wheels both front and rear on my new C6. Have been told the stock size of 245/40-18 in the front should be fine and that 285/40-18 in the rear would be a good fit and compare favorably with the stock 19" size wheel/tire.
What I am wondering is what tires TireRack has that would be good on these wheels.
Thanks Luke.
Marty
ByByBMW is offline   Reply With Quote
Old 02-20-2005, 01:44 AM   #2
DJ Self
CF Senior Member
DJ Self's Avatar
Yeah, Me to. But I want to put a drag tire on the back. A Nitto 305/35 would be nice. OR a bfg 315. What rims would work also? IM thinking about the SSR's.
DJ Self is offline   Reply With Quote
Old 02-20-2005, 12:26 PM   #3
ByByBMW
CF Senior Member
ByByBMW's Avatar
Looks like we aren't going to get an answer. Personally, I have decided to go with Toyo T1-S's, which the tire rack doesn't carry. Wish they would but assume there is some sort of issue with Toyo/their dealers/TireRack.
Old 02-23-2005, 08:44 PM   #4
elh0102
CF Senior Member
I am also going to all 18" on my C6; probably the CCW three-piece street wheel in 9.5 and 11.0 widths. If you are going to the expense of new wheels, you might want to consider going slightly wider; just be sure you get a set with the proper rear offset, which is almost an inch more than the C5. I am going to use 265/35 and 295/35, the same as the C5 factory ZO6 widths. I think I will use the Michelin PS2, but there are lots of choices in those sizes. I think you might find the 285/40 a bit restrictive in availability. I have a set of the BF Goodrich KDWs now, and it's a good handling tire for the money, but noisy. I used them on the track recently, and was very satisfied.
elh0102 is offline   Reply With Quote
Old 02-24-2005, 03:58 PM   #5
ByByBMW
CF Senior Member
ByByBMW's Avatar
You are right, the 285/40 is more restricted when it comes to tire availability. I went with the Toyo T1-S which is supposed to be pretty good. The PS2 and GS-D3 maybe even better. The GY isn't available in 285/40. Will see how the Toyo's work out.
Old 02-24-2005, 11:18 PM   #6
Alex Levy
CF Senior Member
Alex Levy's Avatar
Thanks Luke.
Marty
Simple...
18x18 and with an agressive enough offset to go as wide as you like. Fitments for both C5 and C6..
Alex Levy is offline   Reply With Quote
Reload this Page Recommendations for 18's F & R ?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
