Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-14-2005, 08:10 PM   #1
blkblt97
CF Member
blkblt97's Avatar
Default What is needed for 92 wheels to fit an 87
I am looking at purchasing some 92 Callaway Bridgestone run flat rims to put on my 87 vert. Can some oneone let me know what is required to make these wheels fit my car? If it takes a 1/2, 3/4 or 1 inch spacer don't you need to also install longer lugs? If so what kind of cost I am I looking at to make the wheels fit?
blkblt97 is offline   Reply With Quote
Old 02-14-2005, 09:32 PM   #2
c4cruiser
CF Senior Member
Support Corvetteforum!
c4cruiser's Avatar
There are adapters available that will allow a factory 88-96 wheel fit earlier C4's. Because the adapters use an acron-style lugnut to attach the adapter to the hub, the wheel must have a recessed area on the inside wheel mounting flange. Factory wheels and a few aftermarket wheels have these recesses between the lug holes. Adapters can run around $200-250.
The alternative is to use a spacer of about 3/4" to put between the hub and the wheel. This extends the wheel (and the load) out from the studs and may cause excessive stress on the studs. Longer studs would be needed and a change to a much stronger stud would be my recommendation.
c4cruiser is offline   Reply With Quote
Old 02-15-2005, 01:21 AM   #3
MYCoupe
CF Senior Member
MYCoupe's Avatar
A 3/4" adapter is what you need to mount those wheels on your car. Even with longer studs I don't think that it would be safe to use spacers. Adapters bolt to your existing studs and then you mount the wheels to the studs on the adapters.
__________________
MYCoupe is offline   Reply With Quote
Reload this Page What is needed for 92 wheels to fit an 87
Tags
87, corvette, fit, wheel
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
C4 Technical Summary and FAQ - Please Read on a Regular Basis. bogus C4 Tech/Performance 82 09-15-2011 12:07 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
