Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-11-2005, 05:09 PM   #1
codyusa
CF Senior Member
CI 5-6-7-8-9-10 Veteran
codyusa's Avatar
Default 315-35-17
I have an '87 and considering putting some 315-35-17 on 11" rims- rear only. Any idea how far the tire will stick out? I know the backspace is 7.397". If they do stick out, is there any other backspace that could be used to alleviate this problem? Thanks in advance.
codyusa is offline   Reply With Quote
Old 02-11-2005, 08:46 PM   #2
vetster86
CF Senior Member
vetster86's Avatar
My 86 with 17x11 rear 315/35/17 tires, they line up perfect with the top lip of the wheel well. My off set for the rear is 7.75 but that could be because of the wheel design. See my photos in my sig
vetster86 is offline   Reply With Quote
Old 02-20-2005, 10:16 PM   #3
YorkL8apex
CF Senior Member
Support Corvetteforum!
YorkL8apex's Avatar
Quote:
ZR-1 size rear wheels will fit perfectly on an 87 with 315's Be sure ot get the ZR-1 (37mm)and not the Grand Sport Offset (50mm)
YorkL8apex is offline   Reply With Quote
Old 02-22-2005, 06:23 PM   #4
Swedish Hot Rod
CF Member
Swedish Hot Rod's Avatar
Hi.
Will these rims (with 36 mm offset) and 315/35-17 also fit on a car (1987) that has been lowered?
And what about 335/35-17 on these rims. Will that fit on a standard height car or a lowered car?
Would really appreciate an answer from someone with experience on this.
Swedish Hot Rod is offline   Reply With Quote
Old 02-22-2005, 07:37 PM   #5
Coupe89
CF Senior Member
St. Jude Donor '05-'06
Coupe89's Avatar
84-87 36mm
89-96 50mm
Not sure about the 88
Coupe89 is offline   Reply With Quote
Old 02-25-2005, 02:52 PM   #6
Iliad
CF Senior Member
Default ZR1 Rim 36mm offset
I have one rear ZR1 rim for sale in the size you need. It is size 17.2x11x36 94'-95' ZR1 a-mold. This is a genuine GM rim, not a repro. It has the correct GM part number 10214047 stamped on the inside of the rim. The rim is in great condition. Extra pictures available.
Illiad
Iliad is offline   Reply With Quote
Old 03-02-2005, 06:10 AM   #7
Swedish Hot Rod
CF Member
Quote:
Originally Posted by Swedish Hot Rod
Hi.
Come on, guys, someone out there with these rims and tires (11x17 with 315/35-17) must have an opinion (or guess) on this:
- Is it possible to lower a car like this (1987) or will the tires hit the rear fender?
Old 03-03-2005, 09:36 PM   #8
85 Stalker
CF Senior Member
85 Stalker's Avatar
My car is lowered, and there are no problems at all with clearance. 11x17 with 315's
85 Stalker is offline   Reply With Quote
Old 03-12-2005, 12:43 AM   #9
BOWTYE8
CF Senior Member
BOWTYE8's Avatar
check out the pics of my 85 with true GM ZR1 wheel.(yes GM wheels) I was running 17*11 on he back and 17*9.5 in the front with spacers. The rears require no spacer if true GM ZR1 wheels pre 88.
85 vette pics
Dennis
__________________
2006 LMB Z06 Ported TB and Intake, Vararam, Dynotune 484HP 11.38@125.83
http://bowtye8.tzo.com/
SOLD- 2001 Navy Blue Coupe A4-Dynatech Headers, Borla Stingers,Yank SS3600,3.73's and Vara Ram...Pics-2001 Photos
SOLD-85 Vette 383,ZF6,4.10's new best ET 11.32@123.2 60' 1.58
With 100hp nitrous 11.05@130 See some of bowtye's movies.
BOWTYE8 is offline   Reply With Quote
Old 03-19-2005, 08:33 PM   #10
STREETKNIGHT
CF Senior Member
St. Jude Donor '03-'04-'05-'06-'07
I have an 87 and had those same wheels (17x11) 36mm on the rear with BFG 315's.
Had the car lowered with the Vette brakes lowering kit and NEVER had a bit of problems with it rubbing or scraping. They didn't stick out and made the back look W I D E.
Not to mention the traction in the twisties
They're fine, go for it and enjoy
I'll see if I can find some pics and mail them to you.
Gordon
STREETKNIGHT is offline   Reply With Quote
Old 05-23-2005, 08:31 AM   #11
Thunder Kiss
Junior Member
Thunder Kiss's Avatar
Hey Codyusa, did you end up getting those wheels? If so do they fit OK?
I assume they are the AFS wheels you are looking at. What I can't figure out is they say the backspace is 7.397" but factory ZR1 wheels are 7.93". Theoretically, that means they stick out a further half inch past the gaurd over standard ZR1 wheels.
Is this correct?
__________________
Thunder Kiss is offline   Reply With Quote
Reload this Page 315-35-17
Tags
31535, 86, corvette
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Just installed 17x11 with 315-35-17 vetteaddic C3 General 19 09-22-2005 07:14 PM
17X9.5 Z06 Wheels with 315-35-17 Nitto Drag Radials NJVetteGuy C5 Parts for Sale/Wanted 14 05-25-2004 01:22 AM
Nitto 555IIR in 315/35-17 Size? No Go Wheels & Tires 14 02-16-2004 05:24 PM
315/35/17 tires Eric 96 C4 General Discussion 27 02-03-2004 04:50 AM
Need recommendation on 315/35/17 tires GlennS87 C4 Tech/Performance 21 09-10-2002 12:46 AM
315-35-17 Drag Radials Ram Air Tony Wheels & Tires 30 09-26-2001 01:06 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
