Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-05-2005, 06:00 PM   #1
pwoolford
CF Senior Member
St. Jude Donor '08
Support Corvetteforum!
pwoolford's Avatar
Default Will 17 x 11 fit 1995
I am sure this topic has been beaten into the ground but I cannot find the search option anywhere on the forum today.
I have a 1995 and am looking at new wheels. Can I use 17x11 on the rear? If anyone has done this please post pics.
Here are specs from ebay:
17" x 9.5" (+56mm offset with 7.4" backspacing) rims for the front and two 17" x 11" (+50mm offset/7.93" backspacing) for the rear.
Thanks in advance,
Phil
pwoolford is offline   Reply With Quote
Old 02-05-2005, 10:17 PM   #2
MYCoupe
CF Senior Member
MYCoupe's Avatar
Thanks in advance,
Phil
They will work because those are the GS offsets, which is what you need. There are plenty of members out there with those wheels so someone will probably post a pic soon. The rears will stick out 1/4" to 1/2". You can either put on the GS flares if it bothers you or leave it alone.
__________________
MYCoupe is offline   Reply With Quote
Old 02-06-2005, 01:53 PM   #3
pwoolford
CF Senior Member
St. Jude Donor '08
pwoolford's Avatar
Sweet car! What size wheels do you have on the back?
Old 02-06-2005, 03:08 PM   #4
MYCoupe
CF Senior Member
MYCoupe's Avatar
Thanks for the compliments. Out back I have stock Z06 wheels, 18x10.5" with 295/35/18 tires. They fit perfect.
Old 02-25-2005, 02:14 PM   #5
Lichen
CF Senior Member
Lichen's Avatar
Quote:
So what would happen if I tried to use original 11" ZR-1 sawblades with the wrong offset? I know they would stick out, but would there be any other problems? Handling? Safety?
Lichen is offline   Reply With Quote
Old 02-25-2005, 09:56 PM   #6
MYCoupe
CF Senior Member
MYCoupe's Avatar
Quote:
They will stick out considerably, to the point where it would be illegal. Remember the ZR-1 was 3" wider to accomodate these wider wheels and tires. The handling would be ok. You can probably use GS fender flares to help cover them. Personally I would just go with the 50mm GS offset.
Old 02-26-2005, 02:45 PM   #7
TA
CF Senior Member
TA's Avatar
Here's a pic of 17x11s on my 91. It should give you a good idea how far they stick out. I'd expect it to be similar on your car.
TA is offline   Reply With Quote
Reload this Page Will 17 x 11 fit 1995
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
C4 Technical Summary and FAQ - Please Read on a Regular Basis. bogus C4 Tech/Performance 82 09-15-2011 12:07 PM
Just bought an 01 Z06 I have ALOT of questions, and some money for mods Shawn MacAnanny C5 Z06 Discussion 16 04-27-2005 12:15 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
