Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-31-2005, 04:52 PM   #1
RCK1999
CF Senior Member
RCK1999's Avatar
Default wheel weights
I will shortly be switching from painted rims to chrome. Currently my painted ones have the standard wheel weights that are crimped on the lip of the rim. In looking at other "chromies", I see that some still use the "crimp-on" style while others use the stick-on square weights. Any opinions on which is better??????
RCK1999 is offline   Reply With Quote
Old 02-01-2005, 11:31 AM   #2
MYCoupe
CF Senior Member
MYCoupe's Avatar
Well I don't know that one is better than the other. The factory uses the clip on weights because they are cheaper and don't tend to come off. Aesthetically the stick on weights look better because they can be placed inboard of the lip for a clean look. Some people complain that the stick on weights tend to come off. In my experience if you clean the mounting surface well they seem to stay on just fine. I would go with the stick on weights. Hope this helps.
__________________
MYCoupe is offline   Reply With Quote
Old 02-01-2005, 05:28 PM   #3
smack123
CF Senior Member
smack123's Avatar
I just always have the clip-on's mounted on the back side of the rim. As long as it's not on the face of the rim I don't care, I just don't want to see it. If anything, the clip-on's would be less visible especially if you have open slotted rims (like ZR1's)
smack123 is offline   Reply With Quote
Reload this Page wheel weights
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
CCW wheel weights Darion C5 General 27 05-24-2005 10:29 PM
Wheel weights, where located. german72 C5 General 11 04-25-2005 03:00 PM
? on wheel weights JUSAKD C5 General 11 04-04-2005 10:29 AM
Does removing the wheel weights leave a mark? Trebor C5 Z06 Discussion 10 02-01-2005 09:09 AM
No wheel weights Mark S. C6 Corvette General Discussion 9 12-31-2003 02:32 AM
Why Does GM put wheel weights on the OUTSIDE of .... Z28Z28 C5 Tech 32 05-30-2003 09:21 AM
Factory Wheel Weights Marred Clear Coat!!!! Closer_2001 C5 Tech 10 10-25-2001 03:48 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
