How much is a c6 z worth that needs a motor?
#42
my heads are done on my 06Z, they were done at 32k miles and now have 58k miles
i hope i never drop a valve, but if it does i will get a Dry Sump LS3 and call it a day
#43
Banned Scam/Spammer
very interesting, my brother did work at speed inc and they did everything but the bronze valve guides and he dropped a valve also. Looks like the same problem. Not good for you or anyone else. Really suxs. Good luck with everything.
#46
GM should be handling this issue but instead they stick their heads up their asses n ignore it . I was ****ed over to 38000 miles n I was told to kick rocks we r not going to do anything for u even though we see u had issues over the last 2 years . Only mods cai n axle back
#47
I am very sorry hear about your car.
Speed Inc have done a ton of work on my 07 Z06, including solid Stainless 1 Piece Valves trunnion upgrade, Cam, twin disc clutch, A&A Supercharger and etc. I haven't had any issues with my car. I do plan next year to get Speed Inc to check my springs pressure as insurance since they have been in the car about 5 years now.
https://www.corvetteforum.com/forums...o-results.html
http://www.vortechsuperchargers.com/page.php?id=42753
I elected to used all Comp Cams components for my heads and LG Motorsports G7X3 cam.
Please keep us posted your results with Speed Inc and decision about your engine.
God Blessing to you!
#48
I'm glad you've had great results from them,because from what I can tell when start modding you have better odds in vegas.
#49
#50
Just my experience...... I have a 06 Z with the motor currently out of it. I have had the heads fixed with one piece valves and guides done. Now the motor is out of the car because I over revved the motor and cracked a piston. The cam is stock ! My point here is bad things happen for whatever reason, bottom line in my case was owners error. We are dealing with performance cars which as we are all aware of even a HUGE company like GM will not stand behind 100%. I have heard many great things about Speed Inc, I think that is important to mention.
#51
The most significant piece of information is missing in this thread. The valve did not drop. It was bent. From what I am being told, the customer called us saying there was a noise after he down-shifted and got on it. Of course, according to this thread, this happened randomly while going the posted speed limit, in 6th gear...
Regardless, we took the valve covers off, found a bent pushrod. We replaced it, and it still had a tick. The pushrod that we had just replaced, was now bent. We pulled the plug on that cylinder, and took a peak inside with a borescope. We saw damage to the piston where the valve hit. The valve is bent, and hanging up in the cylinder head, which is causing the pushrods to bend. We could not see damage to the cylinder wall. With out further diagnosis, we do not know if the engine is even lost. The customer is obviously not happy with the diagnosis, or paying us for our time, so we did not go any further.
This is using our mild LS7 "street" grind, which is installed in countless other Z06's with out incident. If there was an issue with the installation of the camshaft, the car would have never made it off the dyno. There's conflicting hear-say, however, the evidence clearly indicates a mechanical over-rev.
#52
I also want to say I didn't come on here to bad mouth speed inc, not once have i unless you call asking how a car made this far untill a cam was installed bad mouthing you.I came here to help me make a decision on what to do with a paper wieght with a payment.
#53
#54
#56
#58
Here is my piston and head of the failed cylinder with just a bent pushrod.
Cylinder
Cylinder
