Corvette Forum
Go Back   Corvette Forum > Upcoming Events and Regional Discussion > Southern California
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Southern California Southern California
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 09-30-2003, 01:29 AM   #1
jbsblownc5
CF Senior Member
St. Jude Donor '08
Support Corvetteforum!
jbsblownc5's Avatar
Default Dyno Day at R&D Dyno on November 1ST... Sign up now!
Here is the schedule for Saturday;
9:00 start
12:00 to 1:00 lunch
1:00 to 5:00 or finish
We will schedule every 20 minutes.
Pick you time. first post first choice.
Just check to see what's open, and then post your selection.
If you have a bung in your exaust, you can get air/fuel checked for an extra 20 over the 2 pulls for 40.
I will be taking the 10:00 A.M. slot. :D
Post Away!!!
JB
jbsblownc5 is offline   Reply With Quote
Old 09-30-2003, 02:48 AM   #2
joemoia
CF Senior Member
joemoia's Avatar
Default Re: Dyno Day at R&D Dyno on November 1ST... Sign up now! (jbsblownc5)
9:00 start
12:00 to 1:00 lunch
Post Away!!!
JB
I'll take 9:00AM
joemoia is offline   Reply With Quote
Old 09-30-2003, 03:33 AM   #3
FNC80
CF Senior Member
St. Jude Donor '03-'04-'05
FNC80's Avatar
Default Re: Dyno Day at R&D Dyno on November 1ST... Sign up now! (joemoia)
I'll take the 9:20 slot with an O2 sniffer. :cheers:
FNC80 is offline   Reply With Quote
Old 09-30-2003, 03:53 AM   #4
FNC80
CF Senior Member
FNC80's Avatar
R&D Dyno Service
115 E Gardena Blvd
Gardena, CA 90248
Phone: (310) 516-1003
Old 09-30-2003, 04:28 AM   #5
qs_zo6
CF Senior Member
qs_zo6's Avatar
Default Re: Dyno Day at R&D Dyno on November 1ST... Sign up now! (FNC80)
11am :D
I have Lg longtubes w/no cats is the "bung" were my o2 sensors connected?
qs_zo6 is offline   Reply With Quote
Old 09-30-2003, 11:42 AM   #6
ryan0
CF Senior Member
ryan0's Avatar
Send a message via AIM to ryan0 Send a message via Yahoo to ryan0
Default Re: Dyno Day at R&D Dyno on November 1ST... Sign up now! (qs_zo6)
9:40
:cheers:
[Modified by ryan0, 7:56 AM 9/30/2003]
ryan0 is offline   Reply With Quote
Old 09-30-2003, 01:33 PM   #7
toddalin
CF Senior Member
I'll take 1:00 p.m.
Is a bung really necessary if a car has no cats? Can't they just shove it up the pipe like the smog check stations? Would love to be able to use the oppertunity to check/change jetting/timing.
1964, 331 CI, 4"x14" K&N/Heavily Modified Holley 600 DP/327-350 HP cam/Edelbrock Performer RPM/1" open spacer/lifter valley splash guard/2.02-1.60 valves/pocket ported and port matched camel hump heads/1.52 ratio roller tip rockers/Doug Thorley cermacoated headers/2.5" mandal bent exhaust/Dynomax Ultra-Flow SS mufflers/Mallory Hyfire IV ignition box/high voltage coil/copper-core sparkplug wires.
toddalin is offline   Reply With Quote
Old 10-01-2003, 01:14 AM   #8
jbsblownc5
CF Senior Member
St. Jude Donor '08
jbsblownc5's Avatar
I have Lg longtubes w/no cats is the "bung" were my o2 sensors connected?[/quote]
Do you have sims in the back o2s? I guess if so, you could use one of the back o2 bungs for you air/fuel.
Jegs carries the bung and cap for about 20 bucks. You can have any decent muffler shop install the bung before your cats.
JB
Old 10-01-2003, 01:16 AM   #9
jbsblownc5
CF Senior Member
St. Jude Donor '08
jbsblownc5's Avatar
Default Re: Dyno Day at R&D Dyno on November 1ST... Sign up now! (toddalin)
Quote:
I'll take 1:00 p.m.
He does not have the type of Air/fuel that goes in the pipe, only in the bung, it's much more accurate.
JB
Old 10-01-2003, 01:17 AM   #10
FNC80
CF Senior Member
FNC80's Avatar
What's a bung?
Old 10-01-2003, 01:29 AM   #11
Russ M
CF Senior Member
JB,
He actualy does have one, it is sitting in the corner of his office. He tried it once, after realizing how crappy it was he threw it back in the box.
I am sure he will give someone a great deal on it. :yesnod:
Russ M is offline   Reply With Quote
Old 10-02-2003, 12:09 AM   #12
devo
CF Senior Member
St. Jude Donor '03 & '05
devo's Avatar
Send a message via Yahoo to devo
can i get in at FIVE?
i am going to leave work at 4;30
[Modified by devo, 8:09 PM 10/1/2003]
devo is offline   Reply With Quote
Old 10-02-2003, 12:37 AM   #13
jimman
CF Senior Member
jimman's Avatar
I'm in put me down for one of the early ones
jimman is offline   Reply With Quote
Old 10-02-2003, 01:55 AM   #14
SNW Vette
CF Senior Member
SNW Vette's Avatar
Hi,
I would prefer 10am. Scratch that, I missed your 10 above.
Thanks,
Steve
[Modified by SNW Vette, 12:31 PM 10/3/2003]
SNW Vette is offline   Reply With Quote
Old 10-02-2003, 03:14 AM   #15
jbsblownc5
CF Senior Member
St. Jude Donor '08
jbsblownc5's Avatar
Default Re: Dyno Day at R&D Dyno on November 1ST... Sign up now! (devo)
That will be a crapshoot at this moment, but let's see how it fills up. Any chance on leaving work a bit early?
JB
Old 10-02-2003, 03:16 AM   #16
jbsblownc5
CF Senior Member
St. Jude Donor '08
jbsblownc5's Avatar
Default Re: Dyno Day at R&D Dyno on November 1ST... Sign up now! (jimman)
Go ahead and pick an actual time that's not taken yet.
Thanks,
JB
Old 10-02-2003, 04:54 AM   #17
FNC80
CF Senior Member
FNC80's Avatar
If he doesn't have a sniffer or something equally simple to measure AFR, I need to back out.
Old 10-02-2003, 07:37 PM   #18
2KVetteMan
CF Senior Member
2KVetteMan's Avatar
Send a message via AIM to 2KVetteMan
I will take the 10:20am slot.
What is the minimum car requirements to show up. I would hate for the 10th dyno day schedule to be canceled. :smash:
2KVetteMan is offline   Reply With Quote
Old 10-03-2003, 03:16 AM   #19
jbsblownc5
CF Senior Member
St. Jude Donor '08
jbsblownc5's Avatar
Default Re: Dyno Day at R&D Dyno on November 1ST... Sign up now! (2KVetteMan)
We need 10 cars to make this happen.
Old 10-03-2003, 07:40 AM   #20
cmeflyby
CF Senior Member
cmeflyby's Avatar
Location: Alhambra Calismognazifornia, in the country everyone comes just to complain but won't go back home!
10:40 for me! :cheers:
cmeflyby is offline   Reply With Quote
Reload this Page Dyno Day at R&D Dyno on November 1ST... Sign up now!
Tags
dyno, performance, rd, service
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
