Westend Alignment
Please post address info and phone number when available.
The cell # listed above is correct, he may be too busy to take on new work since he is a one man shop ?
Keep calling is all I can suggest, and yes he is in HB but I don't know the address, is it not list ?
Wanted to circle back on this topic. I reached out to Westend but never got a response. So this past weekend reached out to Rob at Chewerks in La Habra. Chewerks
I got it corner balanced and aligned for $400.00. I just recently did an A&A kit and part of the install was to pin the crank, i decided to pull the harmonic balancer in the process, so the steering rack came out and I had it rebuilt.
All the aligment settings were totally off. The two wheels where both turned in like i was plowing snow. Chewerks got it dialed into a gnats ***!
Just to add my experience re West End, I was there Friday 9/15 for alignment, corner balance, and ride height. Both Darren and Chris were working. Chris took nearly 3 hours as he dialed in the weights after I changed all 4 springs and some suspension arms. I was charged the standard rate of $450 which to me represented a good value and more importantly, top-quality work. I had zero issues contacting Chris, called and left a VM and he promptly called me back and we made the appointment. I followed up with texts which were promptly returned. The phone number is 310-808-9233 and the address in HB is 5422 Oceanus Dr,
Just to add my experience re West End, I was there Friday 9/15 for alignment, corner balance, and ride height. Both Darren and Chris were working. Chris took nearly 3 hours as he dialed in the weights after I changed all 4 springs and some suspension arms. I was charged the standard rate of $450 which to me represented a good value and more importantly, top-quality work. I had zero issues contacting Chris, called and left a VM and he promptly called me back and we made the appointment. I followed up with texts which were promptly returned. The phone number is 310-808-9233 and the address in HB is 5422 Oceanus Dr, which I belive is mentioned earlier in this thread.
