AutoX: POC- ElToro-Not Great !!!
This was my next to best run of day in practice. Best 56.1 did not record which was only 2 seconds behind fastest cars. Timed runs was off a second and best run ended up losing it on one turn
This is how the day started .......... first run!!
Then my car broke down on way home and had to have it towed ........... !!!!!!!!!!!!!!!
DH
DH
This event was the Porsche Owner's Club. They are friendly to non-Porsche drivers at their events. They currently run most of their events on the old El Toro runway (or what little is left of it). We usually have at least 4 or 5 Vettes each month (Ron, James, Keith, Howie, Bill, Hoi and myself....7 this last event).
http://poclive.com/ for schedule and registration links.
DH: Sorry to hear the car broke. Hope all is fixed now.
Your spin video perfectly illustrates a Corvette characteristic that I keep trying to explain to autocross course designers. They typically leave a bunch of space on the outside those tank slapper type of turns ("for the Corvette guys") and leave nothing or plant a course worker on the inside. I keep telling them that we typically spin towards the inside on those. I've done it myself a couple of times (and my car has been in the weeds twice with miles of space on the outside, but little on the inside). My theory (and I'm by no means an expert) is that we (Corvette drivers) will charge into those corners, brake hard (digging the nose in), start to turn in (starting the rotation), then we either turn too hard or hop back on the gas too hard with little weight on the back wheels (thus removing all grip in the back end) and around you go. The dug in front wheels have grip and this ends up "slinging" the car around to the inside (or at a minimum in a straighter line direction), not to the outside. This is just a theory, but I've watched it happen to a number of Corvette drivers in the past. From your video, I think you even made it through the next gate....which was at least 30 degrees to the inside of the direction of travel before the spin turn.
Need a new clutch and all the other suff that goes with that
DH
