Can't remove front lowering bolt!
Hey guys I decided I'm gonna remove both front lowering bolts but I stripped the driver side bolt so now it won't turn so what can I do to take it out and do I have to drop the A-arm or can I just jack up the spring? Any help is appreciated👍
Thanks guys,
Manny
Thanks guys,
Manny
I would drop the a-arm and unscrew in from the bottom. Its pretty long and comes out the bottom... spray some PB or WD-40 on it and let it sit for a little bit and use a small jack to relieve the tension on the spring and it should come right out without any issue.
Thanks,
Manny
Its a shop...I'll be here all day for the most part.
