2010 Corvette Challenge Rules and Information - Final
2010 Cal Club Corvette Challenge by Speed Ventures
Corvette Challenge Series Rules
Subject to change
Schedule
Feb 20 – Willow Springs Big Track (CW)
Apr 11 – Buttonwillow (13CW)
May 2 – Street of Willow (CW)
June 12 - Willow Springs Big Track (CW)
July 10 – Laguna Seca
Aug 15 – Auto Club Speedway (Roval)
Sep 25 – Buttonwillow (13CW)
Nov 21 – Auto Club Speedway (Roval)
Season Activities
* Award Plaques for event winners
* Trophies for season winners
* Free Corvette Challenge T-shirts for drivers
* 4 BBQs (Dates: 4/11, 8/15, 9/25, 11/21)
* Trophy Girl at final event
* Gift Certificates / Raffle Prizes
Points System
Lowest event's score will be dropped
1st: 12
2nd: 9
3rd: 7
4th: 6
5th: 5
6th: 4
7th: 3
8th: 2
9th: 1
Car Classifications
1. Stock
2. Super Stock
3. Modified
4. Super Modified
5. Ultimate
6. Exhibition (no points / no trophies)
Car Classification Rules
Stock Class
C4 - 150 point allowance
C5 - 50 point allowance
C5 Z06 - no point allowance
C6 - no point allowance
Super Stock Class
C4 - 250 point allowance
C5 - 150 point allowance
C5 Z06 - 100 point allowance
C6 - 100 point allowance
C6 Z06 - no point allowance
Modified Class
C4 - 350 point allowance
C5 - 250 point allowance
C5 Z06 - 200 point allowance
C6 - 200 point allowance
C6 Z06 - 100 point allowance
Super Modified Class
C4 - 450 point allowance
C5 - 350 point allowance
C5 Z06 - 300 point allowance
C6 - 300 point allowance
C6 Z06 - 200 point allowance
C6 ZR1 - no point allowance
Ultimate Class
C4 - 650 point allowance
C5 - 550 point allowance
C5 Z06 - 500 point allowance
C6 - 500 point allowance
C6Z - 400 point allowance
C6 ZR1 - 200 point allowance
Exhibition Class (no points / no trophies)
Any Corvette based car, exceeding the point values of Ultimate Class, i.e. C5R, C6R, GT2, etc.
No Point Modifications
1. Tires: 140+ tread wear
2. Any wheels
3. Alignment - any setting (Removing washers from factory A-arms / Camber kit allowed)
4. Any brake pad / SS pistons in Stock Calipers allowed
5. Any modification to stock rotors (cross-drilling, cryotreating, one-piece replacement, etc.)
6. Any brake fluid
7. Brake ducting allowed / Rerouting of stock brake ducting allowed
8. Any brakelines
9. Any intake
10. Any air filter
11. Any cat-back exhaust
12. Any clutch
13. Any chassis brace (harness bars, roll-bars, etc.)
14. Modified stock throttle body
15. Any thermostat
16. Any radiator cap
17. Any heat shielding
18. Rollbars, seats, or any other safety equipment allowed
19. Any radiator, any oil cooler, any ps cooler, any tranny cooler, any diff cooler allowed in all classes
20. Reliability changes allowed (dual value springs, valves, rocker arms, wheel bearings, oiling system changes)
21. C6 Calipers on C5 / C6 Z51 to C6 base brakes allowed
22. All Stock options allowed
23. Brake master cylinder w/adjustable front/rear bias allowed
24. Any Final drive gear change
25. Tiger Shark front end allowed in all classes
26. Weight savings: seats can be replaced, plastic necessary to install rollbar or other safety equipment can be removed, spare tire, jack/tools can be removed, battery replaced. Nothing else can be removed.
Point Modifications
Engine/Power
1. Turbocharger (ECU tune included) +100
2. Supercharger (ECU tune included) +100
3. Internal Mods to stock motor (ECU tune/ported manifold&heads included) +100
4. Remove Catalytic Converter +25
5. Headers +10
6. ECU retuned +25
7. Ported intake manifold +5
8. Ported heads +10
Tires
9. Treadwear: 100-139 (Toyo R888, Nitto R, etc) +25
10. Treadwear: 50-99 (MPSC, Kumho V700, etc) +50
11. Hooiser R6 / Kumho V710 / BFG R1 +100
12. Hooiser A6 +125
13. Non-DOT slicks +150
Transmission
14. Close ratio Transmission +20
15. Sequential Transmission +75
Suspension/Brakes
16. Coilovers (shocks & springs) +50
17. Shocks Adj & Non-Adj (w/stock springs) +25
18. Springs (w/stock shocks) + 15
19. Front and/or rear swaybars (including removal) +15
20. Front and/or Rear A-arm change + 15
21. Rear tie rod change (bumpsteer kit) +10
22. Bushing/Endlink Change + 10
23. Any Changes to Brakes not allowed in Stock Class (Two-Piece Rotors included) + 20
24.1 Two-Piece Rotors +10
Aero
25. Active Rear Wing +60
26. Rear Wing +40
27. Rear Spoiler (non-OEM) +20
28. Rear Wing and Rear spoiler (running both) + 55
29. Front end/aerodynamics (non-OEM air dam/splitter; front winglets & bumper reinforcements included) +20
30. Non-wing rear end aero (diffuser) +15
31. Side aero (Side Skirts) +15
32. Vented Hood + 10
Misc
33. SCCA-Licensed Drivers with more than Five (5) SCCA T1 podium finishes, entering a T1-prepared car, must run in Ultimate Class
34. Any removal of interior panels, carpeting, windows etc. not necessary for some valid reason (i.e. fancy stereo system) +10
35. Removal of Air Conditioning Unit +5
Safety
36. Any Rollbar providing increase in safety over stock (not harness bar) minus 15 pts
37. HANS, R3, et al safety device minus 15 pts
38. Fire Extinguisher (must be properly mounted) minus 5 pts
This classification system is subject to change because people always find sneaky little loopholes.
ANY MODIFICATION NOT LISTED ABOVE MUST BE REPORTED BEFORE AN EVENT OR YOU MAY BE DISQUALIFIED. THOSE MODIFICATIONS BELIEVED TO PROVIDE PERFORMANCE ADVANTAGES WILL BE ASCRIBED POINTS BEFORE CARS GO ON TRACK.
Specific Rulings
1. Drivers are limited to running in only one Class per event. Drivers may run in a "higher" Class.
2. Drivers must be present at the trophy ceremony to win their trophy. Exception is made for No. Cal drivers (living > 250miles from Los Angeles)
3a. Drivers must participate in 3 or more events, to be eligible for a "Season Ending" trophy
3b. Drivers must be present at the event to win their "Season Ending" trophy; they need not run that day. Exception is made for No. Cal drivers (living > 250miles from Los Angeles)
4. ANY DRIVER WHO MAKES DISPARAGING REMARKS ABOUT A CORVETTE CHALLENGE SPONSOR FOR ANY REASON WILL BE BANNED FOR THE ENTIRE YEAR FROM COMPETING AND WILL FORFEIT ANY POINTS AND TROPHIES!
Subject to change
Schedule
Season Activities
Points System
1st: 12
2nd: 9
3rd: 7
4th: 6
5th: 5
6th: 4
7th: 3
8th: 2
9th: 1
Car Classifications
1. Stock
2. Super Stock
3. Modified
4. Super Modified
5. Ultimate
Stock Class
Super Stock Class
Modified Class
Ultimate Class
2. Any wheels
6. Any brake fluid
8. Any brakelines
9. Any intake
10. Any air filter
12. Any clutch
15. Any thermostat
Point Modifications
Engine/Power
5. Headers +10
6. ECU retuned +25
8. Ported heads +10
Tires
12. Hooiser A6 +125
Transmission
Suspension/Brakes
Aero
26. Rear Wing +40
Misc
Safety
Specific Rulings
Got a few PM's asking what the "Active Rear Wing +60" mod is.
Check it out:
http://www.breathlessperformance.com...arbonFiber.asp
Check it out:
Classification Spreadsheet
I've created a spreadsheet to help in your classification for your car. It's beta, but I think all the bugs are ironed out. Nothing new, just allows you to play a couple what-ifs with different setups. Click the appropriate link on my exciting Corvette Challenge title page:
http://www.augustdigital.com/cc
-pp
-pp
-pp
-pp
Are you gunning for the Geekmiesters job ???
Nice work ....
DH
Very nice work. Too bad I don't have any use for it anymore.
-pp
-pp
-pp
-pp
http://download.cnet.com/OpenOffice-...-10263109.html
DH
I actually read the rules for the first time I discovered that I was 10 points over the required parts to qualify for modified that blows. Man if someone only made a roll bar for my car I'd that really works, maybe I should get a Hans device.
Yes, sell me your sway bars or get a Hans
The thought has crossed my mind on both items, how much is a Hans will I need a special helmet? In fact I've done my fastest times at WSIR on MPSC and stock sway-bars. When I look as "CLion's" times I know that the car is capable of quick times with nothing but Hoosiers, I like his approach of not adding things to his car, I should have followed his lead.
