12-02-2009, 11:32 AM
CF Senior Member
Quote:
Originally Posted by MarkT 2002
The rears definately will make the same clunking sound or even worse. When I had mine installed, after one week the clunking from the rear was terrible. The rubber bushings on the top of the coilovers have a tendency of "settling" and creating a gap so you may have to retorque the top nut. They are a pain to get to so when mine came loose we actually added a second nut to make sure the nut(s) don't back out.
Pfadt is very aware of this problem, I think they even talk about it in their FAQ section. I've been told that Pfadt updated their top nut mounts to eliminate this problem, but in my case the retorqueing and second nut solved the problem - going on two years now.
Thank you !
