Corvette Forum
Go Back   Corvette Forum > Upcoming Events and Regional Discussion > Southern California
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Southern California Southern California
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-15-2009, 02:21 AM   #1
pcfred
CF Senior Member
St. Jude Donor '05
pcfred's Avatar
Default Vette shut down on Freeway
Coming home today the Vette shut down on the freeway , I had just enough momentum to pull over to the right shoulder. Called Joe C whoo was a couple miles ahead of me and he came back to help. The emergency lane was fairly narrow and almost got tagged by some guy ina little white ricer, he then veered left into the middle lade (tires smoking) and luckily regained control. I called AAA then CHP who showed up and sat behind me with lights flashing til AAA got there. It seemed I was out of gas even though the gauge said a little over a quarter tank left. They put 2 gal. in and after a couple tries the car started. CHP bocked the lane to give Joe and I time to get back on the fwy. and a quarter mile down the road she died again I got it started again after 3 attempts and got off at the next exit.
Told the CHP officer I'd take surface streets home and took off, all the while getting Active Handling, and check engine warnings. Got home shut her down and it would not start again unless I pressed the pedal to the floor then turned the key. I was able to do that a couple time after which even that didn't work. I pulled codes, checked voltages, ground wires, and the best I can guess is the fuel pump may have died.
pcfred is offline   Reply With Quote
Old 11-15-2009, 02:34 AM   #2
oldmansan
CF Senior Member
St. Jude Donor '09
oldmansan's Avatar
That sucks. In my other car I can turn the key to on without starting it and I can hear the fuel pump. Not sure how to do that on a Corvette.
San
oldmansan is offline   Reply With Quote
Old 11-15-2009, 02:42 AM   #3
starzilla2
Junior Member
starzilla2's Avatar
that is bad hope you get your vette up and running did you also check with those people at autozone?? if they dont fix it dont get so at them kk
starzilla2 is offline   Reply With Quote
Old 11-15-2009, 03:34 AM   #4
D C
USMC (retired)
Support Corvetteforum!
D C's Avatar
Sorry to hear that Fred. Hope you get it rectified.
You should be able to hear the pump when you turn the key on like previously stated.
D C is offline   Reply With Quote
Old 11-15-2009, 04:33 AM   #5
B R
CF Senior Member
B R's Avatar
Location: Los Angeles, CA.... I know a guy who has a Lambo with Corvette doors
Fuel filter clogged??
B R is offline   Reply With Quote
Old 11-15-2009, 10:00 AM   #6
boblav
CF Senior Member
St. Jude Donor '10
boblav's Avatar
Happy to hear that you guys are OK, and the ricer didn't lose it!
As for the Vette, I agree that the fuel pump/gauge sender could have died, by why the active handling code? Yeah, maybe the fuel filter/regulator is plugged up, have you ever replaced it?
I have the 03 factory service manuals if that would help, you are welcome to use them.
Try adding a few more gallons of gas first.
boblav is offline   Reply With Quote
Old 11-15-2009, 10:29 AM   #7
vinceg
CF Senior Member
vinceg's Avatar
Default check first
Quote:
vinceg is offline   Reply With Quote
Old 11-15-2009, 10:52 AM   #8
Keith N
CF Senior Member
Keith N's Avatar
Fred - Sorry to hear about your Vette. I'm happy to hear you're okay. Good luck in resolving the issue soon.
Keith N is offline   Reply With Quote
Old 11-15-2009, 12:01 PM   #9
Wicked C5
CF Senior Member
St. Jude Donor '04
Wicked C5's Avatar
Send a message via AIM to Wicked C5
Sorry to hear that Fred. I agree really sounds like the fuel pump. Post some DIC codes and I can tell you more.
__________________
Vette #16 and my 12th C5
2003 Corvette Z06
427 C5R Forged Edelbrock 245 heads
230-240-115 Cam
American Racing Headers
A&A YSI Supercharger 80# injectors with second pump
Suspension/brake Mods Coming Soon
http://www.cunningham-motorsports.com/
Wicked C5 is offline   Reply With Quote
Old 11-15-2009, 05:01 PM   #10
mcc978
CF Senior Member
St. Jude Donor '10-'11-'12
mcc978's Avatar
Wow, thats a crazy situation. Does sound like a fuel pump problem. Glad you made it home ok and good luck with fixing this problem.
mcc978 is offline   Reply With Quote
Old 11-15-2009, 05:03 PM   #11
Chuck A
CF Senior Member
St. Jude Donor '08-'09
Chuck A's Avatar
update please.
Chuck A is offline   Reply With Quote
Old 11-15-2009, 05:44 PM   #12
pcfred
CF Senior Member
St. Jude Donor '05
pcfred's Avatar
Default Update
Went out this morning and she started right up, ran just fine. I let it run for about 5 min. shut it down and it started up just fine again, no codes. Good power everything seemed normal til I shut down and tried to start again the service traction control came up. I pulled it out of the garage and started checking wiring, ground points, etc. She would not start. I turned the key to "on" I could hear the fuel pump then after a few seconds started the car right up. Did that a couple times (I had to let it sit in the "on" position for a few seconds each time). I cleaned the throttle body and carefully cleaned the air sensor & screen. She started right up. shut it down then it didn't want to start again. I let it sit for 5 min. then she started but I again got every message in the book, active handling, security, check engine light, etc.
Sooo I'll be calling Lake Chev. in the morning
Old 11-15-2009, 05:50 PM   #13
oldmansan
CF Senior Member
St. Jude Donor '09
oldmansan's Avatar
With all those codes being thrown is it possible you have an electrical problem? I can't see why you'd throw some of those codes if it was just fuel/fuel pump related.
San
Old 11-15-2009, 06:06 PM   #14
pcfred
CF Senior Member
St. Jude Donor '05
pcfred's Avatar
Here's a few of the codes:
10-PCM P1518 H C
28-TCS C1298H
58-SDM U1000H
U1016H
U1040H
U1096H
A0-LDCM B2282H
B2284H
B2262H
B2264H
U1255H
U1064H
U1016H
U1096
A1-RDCM B2283H
B2285H
B2263H
B2265H
U1255H
U1064H
U1016H
U1096H
Old 11-15-2009, 06:11 PM   #15
Chuck A
CF Senior Member
Chuck A's Avatar
I have all the codes, let me know if you want me to e-mail them to you.
Old 11-15-2009, 07:29 PM   #16
Dennis Wilson
CF Senior Member
Dennis Wilson's Avatar
Fred, strange as it sounds It might be the battery, Seen a lot of posts about intermittant probs. Codes etc. & many times its the battery or a bad ground. Good luck. Dennis
Dennis Wilson is offline   Reply With Quote
Old 11-15-2009, 08:46 PM   #17
icedancer
CF Senior Member
CI 6-7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09
icedancer's Avatar
Send a message via MSN to icedancer
Hey Fred! Sorry to hear about your troubles.
I had a very similar issue with the 05 C6 a couple years ago, and it drove me nuts.
Finally tracked down as a loose connection on the terminal block supplying the fuel pump.
Once it finally failed to start for the mechanic (started for him over 40 consecutive times), he tracked down the terminal block in minutes.
That does not account for the active handling issue or the engine warning codes, but might be a contributing issue.
good luck!
Tell Joe that I said hey!
icedancer is offline   Reply With Quote
Old 11-15-2009, 09:02 PM   #18
icedancer
CF Senior Member
icedancer's Avatar
Fred, check these threads - similar issues, may be some gems of knowledge in them that help you.
Good luck Fred.
http://forums.corvetteforum.com/c5-t...t-there-5.html
http://forums.corvetteforum.com/c5-t...ne-help-3.html
Roy
Old 11-15-2009, 09:56 PM   #19
Nick 02 Z06
CF Senior Member
Nick 02 Z06's Avatar
Good luck with this. I know how an issue like this can be very frustrating. Gotta love this forum with so much experience and expertise, someone will come up with the answer to your problem.
__________________
2007 Lemans Blue 2LZ Z06< B&B Fusion, Halltech CF 112, ARH Long Tubes w/ Cats, WCCH Stage II LS7 Heads, Custom Grind (CMS)Cam (231/247 114+3 LSA 653/660 Lift), NW 102 Throttle Body, Ported Fast 102 LSXR Intake, RPS BC2 Clutch, MGW Shifter, Nitto NT-05's.
2011 Harley Davidson Dyna Wide Glide; Vivid Black with Flames: Vance and Hines Big Radius, Power Commander V, Big Sucker Intake.
Nick 02 Z06 is offline   Reply With Quote
Old 11-15-2009, 11:23 PM   #20
RoatanMan
CF Senior Member
RoatanMan's Avatar
That sucks Fred, hopefully you will find the issue... Did the CHP give you a ticket for tint when he was behind you...?
RoatanMan is offline   Reply With Quote
Reload this Page Vette shut down on Freeway
Tags
c5, corvette, seconds, shut, shuts
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Had a fun encounter with a cool vette guy... 11secondGP C6 Tech/Performance 33 06-12-2005 10:46 PM
My clutch just farted on me GGWOODY C6 Corvette General Discussion 53 06-04-2005 08:30 AM
Help! 97 Vette died and wont start. nozebleed C5 Tech 9 05-06-2003 12:44 PM
Broken VETTE!!!! STEVOSVETTE C5 Tech 19 12-16-2002 07:35 PM
Everything went down hill after Chris@SpeedDemon installed my stage III heads (long, very long) Tuan Le C5 Tech 35 08-01-2002 10:26 AM
What's the worst thing that's happened to your vette? Qblue92 C4 General Discussion 36 03-18-2002 06:30 PM
what is the fastest (mph) you got your vette 84fieroburton C4 General Discussion 121 11-29-2001 10:09 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
