Corvette Forum
Go Back   Corvette Forum > Upcoming Events and Regional Discussion > Southern California
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Southern California Southern California
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-26-2009, 08:45 PM   #1
givemeurc6
CF Senior Member
Default F.S. LS7 Clutch
I have an LS7 Clutch and Flywheel for sale. Has less than 5 miles on it. Had Charlie at RPM install it and went a different direction. Like new condition. Prefer local sale. Will ship though. Looking for $400 obo. Email auehara@gmail.com.
For Pictures:
http://corvettez06.shutterfly.com/24#24
givemeurc6 is offline   Reply With Quote
Old 03-27-2009, 05:49 PM   #2
PONI ETR
CF Senior Member
Support Corvetteforum!
PONI ETR's Avatar
I'm guessing this wouldn't fit in my LS1??
PONI ETR is offline   Reply With Quote
Old 03-27-2009, 06:46 PM   #3
RyneZ06
Supporting Vendor
RyneZ06's Avatar
Send a message via AIM to RyneZ06
Quote:
you would need a ls2 corvette flywheel, then it would work
__________________
Ryne Cunningham
Cunningham Motorsports
Specializing In Late Model LSX Performance.
26871 Hobie Cir. unit C6
Murrieta, CA
Shop: (951)677-0716
www.Cunningham-Motorsports.com
Ryne-CMS@Hotmail.com
RyneZ06 is offline   Reply With Quote
Old 03-28-2009, 03:50 AM   #4
kvadnais
CF Member
kvadnais's Avatar
Default whatever it's worth...
I did the the "LS7 clutch setup" on my '02 Z06 (which included the following):
LS6 - master cylinder, slave cylinder (i.e. throw-out bearing)
LS7 - flywheel, pilot bearing, clutch plate, pressure-plate
Same setup *should* work just fine with your car too. Good bite, without making the left leg larger. Excellent compromise for price-over-performance.
I had other problems though... after the clutch swap, it didn't resolve some issues regarding "full" clutch-disengagement. I'm planning on replacing the diff with an extreme-duty unit, and changing gears in the process (I'm running a monster of a cam), and while I have it torn apart, I'm going to investigate the real source of the 'hung clutch' issue. I thought it was the old/stock LS6 clutch, but after the upgrade it's still not fully-disengaging. I have a MGW shifter, which I know contributes to the "stiff" feel, but that ain't the problem. Upon a cold 30-second startup, pump the clutch 5-6 times, and attempting a 1st gear insertion, I feel the car 'inch' forward while pedal is fully-engaged. Something else ain't right.
But overall though, the LS7 clutch components in a C5 application seem to work great!
kvadnais is offline   Reply With Quote
Old 03-28-2009, 02:06 PM   #5
PONI ETR
CF Senior Member
PONI ETR's Avatar
Thanks. I went to a 3.90 rear end with my 6 spd (3.42 was stock), and it transformed the car. Unbelievable low end torque. Got it from Dynotech Engineering and no problems in 2 years. I didn't go with the xtreme duty as I'm not that heavily modded and I don't drive the bejesus out of it.
Old 03-28-2009, 07:36 PM   #6
kvadnais
CF Member
kvadnais's Avatar
Hmm... interesting. I was kickin' around 3:90's or a more mild step to 3:73's. Hadn't really decided yet, but your testimonial with 3:90's has me reconsidering an emphasis on those gears more now. Thanks.
Old 03-28-2009, 08:57 PM   #7
PONI ETR
CF Senior Member
PONI ETR's Avatar
You won't be disappointed. I did a before and after 10-60mph test, and it dropped by .9sec. Almost a full second. That's huge.
RPM at 70mph went from 1500 to 1750. No big deal. It also helped the skip shift nuisance. Around town now I go from 1st to 3rd and don't even bother with 2nd. But if I want to shake and bake, it's there.
Old 03-29-2009, 03:58 AM   #8
RyneZ06
Supporting Vendor
RyneZ06's Avatar
i have found if you but a .115" shim behind the slave cylinder is will fix the disengagment issues, i have done this with many ls7 clutches with great success
__________________
Ryne Cunningham
Murrieta, CA
Shop: (951)677-0716
Old 04-05-2009, 12:55 AM   #9
givemeurc6
CF Senior Member
I'm including the flywheel with the clutch, so it's the complete kit for $400 dollars.
For Pictures:
Old 04-05-2009, 01:22 PM   #10
givemeurc6
CF Senior Member
Ttt
Old 04-05-2009, 02:05 PM   #11
jimman
CF Senior Member
jimman's Avatar
sent you an email
jimman is offline   Reply With Quote
Old 04-06-2009, 01:04 AM   #12
givemeurc6
CF Senior Member
Email Returned.
Reload this Page F.S. LS7 Clutch
Tags
bearing, c5, cluch, clutch, corvette, forum, ls6, ls7, pilot
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Weights, measurements, ratios, strengths, etc leaftye C5 General 239 01-18-2012 04:29 PM
C6 Z06 Frequently Asked Questions(FAQ) LTC Z06 C6 Z06 Discussion 56 08-02-2011 03:23 PM
C6 PARTS & TECH NEWS 09-02-05 NEW INFORMATION CorvettePartsBob Ken's Newsletters 12 12-04-2005 01:59 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
