The thermostat on my 2008 LS3 is stamped 86 degrees C which is 186.8 degrees F. It's fully opened at when the cooling temperature reaches 200 degrees F.
Has anyone install a 160 which would mean it should be fully opened at around 174 degrees. I could program my fan to come on sooner as well. Are there any problems doing this i.e. condensing moisture in exhaust, etc.
Here we go again
Ask yourself these questions;
What is combustion efficiency?
What is thermal conductivity with different metals?
How do those two questions above relate?
What happens when you do short trips over a few years of operation?
How does cooler oil temp affect net HP with thicker oil?
Turning fans on sooner, great if fans require no energy to run?
Without changing radiator size do you really think your doing anything of significance?
Does the floor manager of Wal-mart or Macy’s know more than GM Engineering?
And how do we get through the day?
Location: Sandy Eggo, Calif. Don't blame me, I voted for the American
Quote:
Originally Posted by jimman
Here we go again
Was sitting back and waiting for this one!!! I'm sure he will gain .2 hp!!
PM me if you wanna continue this... let's not trash someone's 1st thread...
Let me rephrase, "Not Advisable"
Now which will he remember, just trying to save his motor or who ever buys it from him later on. It's called cylinder wash down caused by short duration trips resulting in improper heated engine leaving excess unburned fuel. This causes next restart on oil free or dry cylinder wall resulting in scored cylinder walls with time. You might ask the question why are all thermostats closed when cold?
Quote:
Originally Posted by MyVetteDream
And maybe he could've done it without all the
pm sent
__________________ '99 FRC 6sp W/A&A Forged 402 and Vortech T Trim/12 lbs boost/Labonte Meth Injection/AR HEADERS/AFR Heads/DTE Brace/8 Rib with Cartek Flip Drive/Yella Terra Rockers/3:90's/RPM Custom Cam/ Tuned by RPM Motors Inc/706 rwhp/627 rwtq.
So long old GAL, it was great running with you!!!!!!!!
Not trying to ruffle any feathers here. But I know some of these "great" people. Their good guys, and will share their knowlegdge when asked for it (and they have a lot of knowledge). But when the thermostat issue has come up I could see the blood pressure rising. So to the OP don't take the tone of the posts personally. This subject has been cleary discussed at length and is a sensitive topic.
While I agree that getting a thermostat at a lower temperature sounds like a good idea. I think it may be a fad mod and I wonder if it has any significant performance advantage. I know that my stock LS1 has no cooling issues and stays at 190 degrees while the car is moving, at any speed or condition. When I am waiting in traffic the temp goes to up to 210. I see nothing wrong with the stock system.
Looking at Jimman's profile;
Biography:
PHD in Solid State and Applied Physics. Hold patent for Thermal Dynamics with Peltier devises involving thermal conductivity.
I think his opinion warrants some consideration.
Jimman, hope you don't mind posting from your profile.
Thank you for your response. It made the most sense. I orgainally spent the weekend installing a 180 degree thermostat because most dealers just call it a 190 deegree stock when in fact it's not. Close but not accurate. So I put in a 180 but it never did work correctly every after setting my fan to come on 15degrees sooner. And quite honestly for a 8.6 degree F differential I saw no benefit. The only one I was able to find was a 160that was the reason for my question.
I like a shared exchanged of knowledge rather than just bashing someone without ever going into a though process of their logic. Thank you, you actually are logical.
Jim, your pretty arragant when a member ask for advice. Here was my post to another member that was will to share knowledge.....
I run with you guys and can't understand why you try to bash me If I knew I wouldn't ask. Not very constructive here my previous reply..... is this the way you interactive with club members.
