Corvette Forum
Go Back   Corvette Forum > Upcoming Events and Regional Discussion > Southern California
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Southern California Southern California
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-22-2006, 06:29 PM   #1
jserio
O.C.
Support Corvetteforum!
jserio's Avatar
Default Targa Top refurbisher
Does anyone know a targa top refurbisher in LA/OC area? My acrylic is basically good it is just that the seal on the driver side between the glass and frame is coming undone. I can actually lift the glass of the frame enough to stick my fingers thru inj the driver rear corner.
joe
jserio is offline   Reply With Quote
Old 04-30-2006, 02:30 PM   #2
ReVetter
Junior Member
ReVetter's Avatar
I don't know if this applies to your situation, but Chevrolet is having a "voluntary customer satisfaction program" (recall) on 2005 Vettes with the painted roof panel.
It says in part, "... the painted roof panel may separate from its frame in some areas if it is exposed to stresses along with high temperature and humidity. ... Symptoms: snapping noise when driving over bumps, wind noise, poor roof panel fit, roof panel movement/bounce when a door is closed, water leak.
What we will do: ... your Chevrolet dealer will apply adhesive foam to ensure proper adhesion. ... In a small number of vehicles, the roof panel may require replacement. ... at no charge."
You might call Chevrolet Customer Assistance at 1-800-630-2438 to see if this voluntary recall can be applied to your car and if they can fix it for free. Who knows, it sounds like this may be a known problem with a known fix and, if so, the factory could just make it a "Goodwill" warranty repair for you.
If you are looking for a dealer to do the work, I'd trust my car with Cormier. They have enthusiastic Corvette people there.
ReVetter is offline   Reply With Quote
Reload this Page Targa Top refurbisher
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
