Headlight door not closing all the way?
St. Jude Donor '05
CI VI Veteran
I've noticed the last few weeks that my left headlight doesn't close all the way. It sticks up about a 1/4". I took a quick look at it and didn't notice any stops that could be adjusted. Obviously owning a bodyshop, I'm quite capable of replacing the thing but I wanted to make sure there wasn't some quirk like the C4's when the bushings use to go out.
I'm assuming without even looking at it something is wrong in the motor because it wouldn't normally just go out of adjustment. The headlamp opens and closes... just not all the way.
Anyone encounter this before?
Thanks,
Mark
Thanks,
Mark
I had a problem on my last Vette but it was just a slight adjustment. If I remember correctly, the panel that covers the top of the headlight has 2 screws on each side that allow for alignment. You can move it forwards, backwards, tilt it up, tilt it down, etc. Just flip the headlight up and you should see the screws on each side.
If thats not it, I dont know what to tell you. I dont know anything about actually moving the headlight bucket itself.
St. Jude Donor '05
CI VI Veteran
Much appreciated but I think the problem is in the motor itself. It's simply not going it's full travel length. When it does, it is adjusted perfect, just once in a while it doesn't close all the way.
Thanks though,
Mark
Thanks though,
Mark
I have a similar problem, except instead of not travelling the entire distance, mine goes all the way down, then comes back up a little bit. I just pop the hood and crank it down flush. It seems like the stops are maybe out of whack? Does it even have stops?
Thanks,
Mark
Thanks,
Mark
http://www.madvet.com/shop?frame=1.5749
Other members have had luck taking out the gear and turning it 180 degrees and extending the life a bit.
Paul
