B&M or Hurst shifter - Tips/comments/opinions/advice?
Thinkin' about replacing my shifter with a B&M or Hurst for my'94 6spd. Hard to do? Worth doing? Don't plan to race - just like the fun of driving it but want to reduce the throw on the shifter.
This is one of those topics that usually starts a "mine is better than yours" discussion. I chose the Hurst shifter over the B&M. If you put both of them side by side, I think you'll pick the Hurst, but if you want the shorter throw, then maybe the B&M is your choice. It's a PITA, but well worth the effort. It's been the most fun mod I have done to my Vette.
Originally Posted by rocco16
Strick,
Time to detail your interior.
(PS the shifter looks great)
Larry
code5coupe
Larry
code5coupe
Elite Torch Red Member
Reducing the throw, why do that, it isn't that much to begin with. Now if you want a better shifter then it's fine. My opinion based on driving cars with both types, the Hurst is the superior shifter. The throw is reduced by 30%(not that you would ever notice).
The B&M is too clunky and hard to speed shift when you want to.
You will lose the reverse lockout either way, but that shouldn't be a problem, I haven't met anyone yet that had a need to powershift into 6th gear.
The B&M is a lot shorter and if that's what you really want, but for daily driving I would go with the Hurst.
I dont own either but i have driven a couple cars with the hurst shifter and it is amazing! its the way the car should have come stock. not to hard or clunky but just right. if you like the way the stock shifts feel wait till you try this one! I have not tried a B&M so i really cant compare but i will say you wont be sorry if you choose the hurst!
Location: St. Peters MO Sometimes you have to prove yourself by doing alot of killing or alot of dying...
It was a huge PITA!!! I ended up having to get help becuase I could not align the shifter and the input shaft to insert a dowl pin... took my 8 hours when the manual says 3... of course I was stubborn and refused to ask for help when I needed it.
All in all it was worth it. I went with a B&M. It is pretty much the same as the Hurst, but the B&M is more notchy like a race tranny feel where the Hurst is smooth like the factory unit. It is a matter of preference as to which is likable. My wife hates the B&M and claims that it hurts her arm to pull the shifter into the next gear... but I love it
I just installed the Hurst short throw on my ZF6 I am installing. I did it on the bench and it was STILL a PITA!!
That said, I think it will be very worth while. I had to file mine to fit the pivot properly. I'm not sure if mine recieved an extra thick coat of power coat, but it fit much tighter than the stock shifter (so tight it was difficult to move the shifter). I measured with a pair of calipers to confirm the Hurst piece was significantly larger. Again, nothing a file didn't fix.
BTW, I got mine off ebay for $117, new in the box. I think they usually go for around 150-200 elsewhere, so it pays to shop around. I also went with the Hurst ball shifter, which was $28 from the same ebay vendor.
i just bought / installed a hurst shifter in my 89 .. i don't know if i was lucky or what but it was a breeze... it seems alot nicer and is tighter.. i like the shorter throw and it feels more positive .. it only took me 4 hours to do it start to finish.. i would however suggest read the directions they do help... as for the b&m shifter i didn't like it .. it seemed you had to muscle it into gear .. to short for my liking but to each thier own.. i was very pleased with the hurst ,.. now if the damn snow will go away i can get out and really give it a run through the gears
I have Hurst and love it.
You really need to try both, to make an assessment.
I don't agree with Frank on the "lack of difference". I noticed it immediately. The throw is much tighter and shorter. And the shifter is shorter, making for a more ergonomic fit.
Mine is a hurst that has been cut down an additional inch or so. I also ran a hurst one one of our previous mustangs. Very good quality. Mine in the C4 does feel a little chunky, but the hurst's typically do come with very heavy springs. This is a plus because the 'centering' of the stick back to the middle groove (nuetral) is very prevelant and machine like. The only shifts I have missed have been power shifts into 5th. (me trying to hard). Usually the hursts seem to 'know' where you want to go.
Sorry I don't have any interior pics of how short my shifter is, but lets just say its definatly short. (no jokes please )
I have recently off-set this by using a billet ball thats tapped for a C5. (shallower thread depth than a C4).
The shorter stick is more comfortable when shifting. Well worth the time to install. In all fairness I didn't have have any trouble slamming gears with the stock shifter but I think the Hurst/B&M might give some people more confidence to bang'em.
Again, Great feedback!
Love this forum. I've gotten great advice on all the ??? I've posted since I've joined. Where the H was this forum when I was stumbling around with my new '73, old '68, old '77, old '80 and 2nd very old '73. Yeah, I'm that old. I take it the exhaust has to be removed to get to the shifter.
Mr. Mojo, You're right. Better shifter is what I want, but the stock throw could be shorter. The stock shifter is very smooth, however. I just HAVE to mod my rides. Can't help it.
I think from all the comments that I'll go with the Hurst. That's what I put in my first '73.
Location: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
Hurst install isn't that bad.
Its not over anyone's head or anything, its just tough to get the pin in place that mates the shifter and tranny together. I just made sure the little pin was in the top portion of the shifting linkage then after sliding it in place pushed it down and whala, done. Now putting the boot back sucked but after a few bad words and a couple of pushes it went on.
Shifts great, love it. Would never go back to stock.
I haven't had both in the same car, but the Hurst in my '99 Camaro SS had a much softer feel (and way longer throw) than the B&M in the C4. The B&M is ratchety, but I like it alot better than the Hurst.
Is this the Hurst shifter you guys are using, and is this a good price?
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT
