Hood Release broken on my C3, need help
4th Gear
Hi all,
I was wondering if anyone here has ever had a problem with their hood release cable snapping. E.g. Is there any way to pop the hood without taking the front end off. The car is a 1969 corvette with a 1973 front end.
release
Actually, Chevy thought of this. There's s small access port on the drivers side in the windshield bay to give you access to the hinge. The hinge has a tab you can push against to release the latch. The cable normally pulls from the bottom, but you'll be pushing at the top. All the catalogs sell a special rod for this, but a long push bar should work. Good Luck!
Had the same problem on my 79. Not sure if it will be same on yours. There should be two holes, one on either side wear the windshield wipers are. There is a plastic insert in it to prevent debris from getting in. Just remove the plastic insert, and with a screwdriver or your fingers (if they are long) you can push down on each hood release mechanism. Hope it helps, but I'm sure it is not necessary to remove the front clip.
(Edit: to slow in the response)
Originally Posted by rumbler
Wow. I'm amazed that you guys knew that. Seems like an extremely obscure problem to me. I'll take a look after work today
We should find a forum and post solutions to common problems there...
Originally Posted by robertmc48
thats getting mounted on the wall in the garage!!!!!!! thks bob
