Cancer in the Birdcage (Large Pics)
Old 02-15-2005, 01:34 PM
kortensi
kortensi's Avatar
I thought that I would toss in a little update here.
I know that it's been a while for this but I went on vacation for two weeks, messed up my back again and got the flu which turned into pneumonia.
Well I finally got back to the old girl this past weekend.
I removed the entire front bumper and grills.
I removed the headlight assemblies and vacuum hoses and wiring.
I removed the vacuum canisters on the inside drivers side fender.
I removed the entire AC system
NO rust on the radiator mounting frame
But I found some on the AC unit itself where it mounts to the firewall.
Its got a nice big hole about 3” by 9”
I started to break the seals where the doghouse meets the firewall/birdcage.
I got nervous though and stopped.
The stuff that seals it together is tough. It looks like bondo and is a pita.
I'm worried about spliting the fiberglass instead of the seam.
It wasn't coming off very easy and I needed to check online and see what I was doing.
Good thing too, because I was trying to separate the wrong area.
Here are some pics of the progress so far.
Disregard the colored lines and markings; I think I got it figured out.
DO NOT REMOVE THAT PART!
IT IS NOT NECESSARY
undefined
One day she will be back together again.
Old 05-20-2005, 10:46 AM
AGVI
AGVI's Avatar
Canadian Events Coordinator
ttt
Old 05-20-2005, 10:53 AM
redvetracr
redvetracr's Avatar
If you or anyone else is interested I have a rust free `71 firewall back coupe rear clip for sale.....with the AC box. e-mail DIRECT if interested!!
redvetracr@msn.com
Old 05-31-2005, 04:58 PM
kortensi
kortensi's Avatar
Default new updates
Hey guys, I'm back.
I'm not sure where the first 6 or 7 pages of this post went.
I finally got back in the garage and started back up on removing the front clip. This has been the toughest thing that I have ever done on this car, so far. Let’s just say that the bonding agent that was used worked really well. I started by trying to slowly chip away at the seams and pry it apart. This does not work very well. For anyone attempting to do this, go out and buy a good heat gun. Once I got the bonding agent heated up, it came apart a lot easier. The drivers side took about 10 hours total and the passenger side, where I used the heat gun, only took about 1 1/2 hours. I split the fiberglass in several places on the driver’s side but the passenger side came off in great shape. Here are some of the pics that I took after it was off. I have a bunch more in higher detail if anyone else is going to attempt this and wants to see how I messed it up.
Old 06-01-2005, 05:13 AM
69Myway
69Myway's Avatar
Looking good. I remember these days. Pretty scary at first, but it gets better as you go.
Looks like you are having fun.
Old 06-01-2005, 01:43 PM
jpatrick636
jpatrick636's Avatar
I've heard about weight reduction but this is too much!
Oh, I get it, your going to put it back together.
KEEP UP THE GOOD WORK. We are with you in spirit.
Old 06-01-2005, 04:24 PM
The_Dude
The_Dude's Avatar
St. Jude Donor '11, '16-'17
It looks like you only have a couple of really bad spots. Certainly not the end of the world. Thanks for the pics. Good luck.
Old 06-01-2005, 04:36 PM
kortensi
kortensi's Avatar
Thanks, it’s definitely not as bad as some of the others that I've seen around the forum. I still want her to be pristine when she is done. I'm going to try out my new welding skills (I just took a class) and see if I can fix her up. If not, I will see about buying the rear clip or birdcage and just putting the pieces together.
KO
Old 06-01-2005, 06:07 PM
vettemad
vettemad's Avatar
Default b-cage
I know it's to little to late, but you might want to look at my post in tech, b-cage opinions & facts ....Cliff
Old 06-12-2005, 11:21 PM
teebone
8th Gear
teebone's Avatar
Keep the updates and pictures coming-great stuff. I have just started taking the cage out of my donor car-no fire wall, only the rear clip, so I am having to learn how to separate the glass on the rear door panel. Trying to get as much practice in as I can before I tackle the front clip.
How much heat does it take to get the bonding agent soft?
Old 08-08-2005, 09:25 AM
RPOZ4Z
RPOZ4Z's Avatar
Cruise-In VII Veteran
I could use some more info on what was involved in removing the front clip and how much heat and exactly where you applied the heat to soften the bonding agent.
I will be doing this to a '73 convertable soon!
Old 08-09-2005, 11:18 PM
kortensi
kortensi's Avatar
No Problem.
I've got all of these pics at work.
I'll draw some updated lines on them and get the type of heat gun I used.
I picked it up from Sears, I think.
KO
Old 08-12-2005, 11:06 PM
kortensi
kortensi's Avatar
Default heat gun
Here is the heat gun that I got.
I'm pretty sure that I bought it at Sears.
I had the setting around 7.
When I had it on a higher setting than that, the paint started to bubble.
I will still get the detailed pics of where it was separated for you; I just haven't had a chance yet.
Old 08-13-2005, 08:38 AM
RPOZ4Z
RPOZ4Z's Avatar
nice!
Thanks!
I have a heat gun that I would like to try and use, I'm not worried about the paint, there isn't any on the car!
To Cancer in the Birdcage (Large Pics)
Quick Reply: Cancer in the Birdcage (Large Pics)
