How To Lower C6
Does lowering the car do anything to the warranty? Also, would you say that the fact the car can be lowered so easily means that GM actually designed it to be lowered?
bacord (03-24-2018)
MONARTOR
I would recommend an alignment after a couple weeks..
Originally Posted by C68888
Anyone have any "how to" pics? It doesn't sound too bad of a mod, but just wanted to make sure I would be adjusting the correct bolt.
Thanks,
Brian
Thanks,
Brian
Here is a before and after of my clients yellow Z51 C6.
It firmed up the ride, but was an improvement in road feel. I turned the front adjusters all the way and cut the rubber off the rear adjusters and backed off 1 full turn from the bottom.
Joshua
Joshua
Lowered mine today. I have the Z51. Rear lowered only 1/2 inch or so and the front 3/4 of an inch. Look appears improved to me and no noticeable driving issues so far. Only removed the rear tires, didn't have to remove the fronts. This was all the stock bolts would allow, which is perfect for me.
Anything to be concerned with on F55?
Hamzat asked about F55 lowering already but has gone unanswered. I too am wondering if there is anything different about lowering an F55 car? Can any of you guys come up with any foreseeable problems with lowering the F55s? Thanks in advance! C
