[Z06] Charge System Fault Message
Old 11-09-2004, 06:40 PM
CorvettePartsBob
CorvettePartsBob's Avatar
Default Charge System Fault Message
This is Bob at Fichtner Chevrolet.
I am working with GM on a “CHARGE SYSTEM FAULT” message on the DIC after changing to the new 140 amp alternator. Every thing is working fine and no DTC codes stored. You reset the dic and it eventually comes back.
I have finally gotten the attention of GM on this problem and they now want your assistance. I have been in contact with GM Parts Technical Assistance and Chevrolet Technical Assistance. This problem is being referred to GM Engineering but they need VIN NUMBERS.
ONLY if you have changed your alternator and received the latest # 10353440 alternator which is 140 amp instead of the original 110 amp alternator; and have had this problem. Please email me your vin #, mileage, name and phone number. All of this information I will be forwarding to GM Engineering and Chevrolet Technical Assistance. They are trying to find out exactly what is going on and why. I doubt if they will call you, but I told them I would ask for the phone number just in case. According to GM they have only had 6 cases of this reported. I know there has to be a lot more out there.
Email me at parts@fichtnerchevrolet.com
Use charge system fault for the subject.
PLEASE DON’T SEND RUMORS OF MY FRIENDS NEIGHBOR SAID.
We need hard info so GM can solve this problem quickly. Here is your chance to help. I promised GM that the great members of the Corvette Forum would come thru for them.
Bob Wendorff
Parts Manager
Fichtner Chevrolet
406-628-4618
Old 11-09-2004, 09:18 PM
Shylor
Shylor's Avatar
I got the "charge system fault" message the other day after I started the car. It went right away though.
Old 11-09-2004, 09:20 PM
MikeNMaxZO6
MikeNMaxZO6's Avatar
Mine has the message only if I don't drive the car for about a week or so.
Old 11-10-2004, 08:15 AM
dwjz06
Dogface
Support Corvetteforum!
dwjz06's Avatar
St. Jude Donor '15, '17
I have gotten the message since the car was new off and on. Had the altenator replaced so I will look for the part number on it. Thanks, Don
Old 11-13-2004, 10:51 PM
dragon84
dragon84's Avatar
I have been getting it for a while on and off. I believe I have the original alternator but not sure, I bought the car with 3,000 miles on it
Old 11-15-2004, 09:31 AM
QuikZilver
QuikZilver's Avatar
Happened on Saturday, but checked the voltage and no problems. Only happened that one time and I still have the factory alt and battery.
Old 11-17-2004, 07:03 PM
zorrozo6
zorrozo6's Avatar
My 2001 just had Charge system fault show up on dash. I have not replaced the alternator or done anything to it in a while. My system is charging fine and I can find no reason to take it back for service at this time.
My Vin # is 1G1YY12S615130877.
George Davis San Diego, Ca 619-246-5202
Old 11-17-2004, 08:18 PM
Shylor
Shylor's Avatar
There should be no reason to take the car in for service if the fault clears itself.
Old 11-17-2004, 09:02 PM
neile
neile's Avatar
CI 3-5-8 Veteran
Default Valid or Invalid Error?
Bob I am of the impression that this is a rather bogus error message for late model Z06's. I experience this error message about 30% of the time upon starting the '03 after it has set for longer then overnight. It clears within a few seconds of starting the car and leaves no codes set in memory. The charging system checks out okay and the battery also checks okay. I have had this error message almost from day one and the car has 19K+ miles and is 20 months old.
Now I would be interested in learning what logic is in the software that brings this code up.
Neil.
Old 11-22-2004, 07:24 AM
LT1GMC
LT1GMC's Avatar
Why are some replacing the alternator with a larger unit? Is this something the newer ones come with, or does it fix a problem(like the lights dimming every time the air pump cycles) or what? Thanks, Steve
Old 11-29-2004, 06:05 AM
lilesv
lilesv's Avatar
Neil.
i don't have an answer, neil -- just butting in to tell you that is one awesome photo in your signature...
Old 12-03-2004, 12:24 PM
J-Rod
J-Rod's Avatar
My car sits at my shop for a week at a time in some cases. I have not replaced the alternator. But, it does do this on probably 50% or more of the starts, and then goes away. I was not aware there was an alternator upgrade, or I would have done it, as my car just went out of warranty (its now on extended warranty so I will have to wait to do it when something else breaks). My car is a 2002
Old 12-04-2004, 09:03 PM
Millenium Z06
Moderator
Millenium Z06's Avatar
Mine does it too, no alternator replaced and only happens if car has sat for a week or so. Dealer said there were no codes found and no voltage problems.
Old 12-10-2004, 04:35 PM
CDH76
CDH76's Avatar
Do you want this info ONLY if we have replaced the alternator? I have had this come up on my past Coupe and my current Z06 but never have I exchanged stock parts in the car. If you want this info w/ or w/out replacing the alt. let me know.
Old 12-11-2004, 09:59 PM
Popclutch
Popclutch's Avatar
Interesting... I JUST had this happen today!! Fault came up on the DIC then cleared itself almost immediately. My Z is a 2002. Is this a problem or what??? I have only had the car a month now. Flipped me out because I NEVER had this happen on my 2000 Vert.
Old 12-16-2004, 04:03 PM
EVIL_C5
Uber Waxer
EVIL_C5's Avatar
Cruise-In 8-9-10-11 Veteran
CI 9, 10 & 11 Car Show Winner
St. Jude Donor '08-'10
me too. but i have a vert and havent changed anything.
Old 12-21-2004, 02:00 AM
Shylor
Shylor's Avatar
I finally got around to clearing the history codes this fault may have caused. I think low battery conditions cause many error messages to be thrown when nothing is really wrong other than a low battery at startup, which easily happens when your car isn't a daily driver.
To Charge System Fault Message
Old 12-24-2004, 01:43 PM
Cruncher
Cruncher's Avatar
My Z06 is a daily driver and I get "the code" two or three times a month. On Monday, I have an appointment to have the alternator replaced with a different model than the original. I had the code with the OEM battery, as well as with the Red Top. "The code" happens only on the first start up of day.
Old 12-28-2004, 05:06 PM
davestanley
Cruising
davestanley's Avatar
Default Charge system fault
I had mine to the dealer 3 times for this. They replaced the battery but the error continued. Then the tightened the starter bolt and it hasn't happened since, go figure. It was doing it one a fairly regular basis and hasn't done it since so maybe there is something to this.
Old 12-29-2004, 12:37 AM
LIGHTNING
LIGHTNING's Avatar
Does this happen only on certain model years??
Quick Reply: [Z06] Charge System Fault Message
