rusting, peeling rotor hats, can they be painted?
rusting, peeling rotor hats, can they be painted?....center of rotors are in need of something. any ideas?
Lepus-temperamentalus
Absolutely!
Check out my page on "Painted rotors". It was really about the calipers but I painted the rotors as well with high temp black paint. They turned out a dark gray and I think that's just fine.
http://forums.corvetteforum.com/showthread.php?t=937910
Mine were rusted and crappy looking too. I used brake cleaner and denatured alcohol and a toothbrush to get them smooth again before the paint job.
St. Jude Donor '04-'05-'06-'08-'09
Yes they can. I helped a friend do his recently. We put the car on jack stands and took the rotors off the car. Then we used a scotchbrite pad from Home Depot paint dept to thoroughtly clean them. It does take some elbow grease and time to do a good job.I have seen some say they used 000 steel wool. We taped off the hats as carefully as possible. Right before painting we used alcohol to thoroughtly clean the area. Then we spray painted 2 coats of high temp black paint. Worked great. I have also heard that you can use a foam pad paint brush to apply the paint.
This does not address the slots or holes but we were not concerned with those from a cosmetic point of view.
Hope this helps. Good luck with your project.
Rust-Oleum High Heat Paint
Received 19,441 Likes
'20-'21-'22-'23-'24
Yes, they can be painted. Sand them down with some very fine sandpaper or some steel wool and then get some caliper paint and paint away. Should turn out nice.
