Mobil 1 Synthetic ATF for a M6?
Would you guys recommend using the Mobil 1 Synthetic ATF in a 6 speed car? Ive got a 97 with 50k miles on it now, and the shifting between first and second are becomming really "notchy." Ive heard that its the "norm" to use ATF in M6 gearboxes...i just want to be 100% sure before i put it into my baby.
Thanks
Thanks
carry265 (02-24-2024)
SE Ohio Event Coordinator
CI-V Car Show Winner
Cruise-In II Veteran
Cruise-In III Veteran
Curise-In V Veteran
Cruise-In VI Veteran
That's what I put in our 98. It really improved the 1-2 shift and seemed to smooth out the others as well.
Received 19,305 Likes
'20-'21-'22-'23-'24
Originally Posted by Midwest Vette
The mn6 transmission uses dexron 3 atf. As long as it meets the dexron 3 specs you should be fine.
So...i should be good to put this stuff in (mobile 1 atf)? eventhough its ATF...this is kinda scaring me...just dont want to screw up my tranny...
Received 1,408 Likes
2017 C7 of the Year Finalist
St. Jude Contributor
I use Royal Purple in my differential and tranny. They are an excellant choice.
Max-ATF for the transmission
http://www.royalpurple.com/prodsa/matfa.html
Max-Gear for the differential
http://www.royalpurple.com/prodsa/mgeara.html
To help you with you question and apparent confusion.
Your 6 speed manual DOES indeed use Dexron III ATF fluids.
Originally Posted by red97vette
did u put in mobile 1 atf or the dextron III?
How easy is it you ask? Draining is easy, just pull both plugs (drain & fill) and let it drain itself. Filling is a little more of a feat, but not all that bad. You'll need 4 quarts and will not use quite all of the last one.
It is easy to know when it's filled to the correct level. Just fill until it starts to come out of the fill hole. When that happens, let that slight overfill run out for a while, then buttion her up and you're done.
I DO NOT recommend using Mobile one Sythetic ATF in your 6speed. I tried using it in my 97 Camaro Z28 6speed and ended up giving me troubles. I was told its because of the type of fluid on the synchros allows them to get too hot and slippery. it must be true because I would once in a while get a grind going into 1st. Problem never happened again after going to a normal dexron III fluid. Also, my 3-4 synchro wore out to and I dont drive my car hard. DO not use that fluid. Just get a normal Dexron III fluid.
What:
Dexron III rated ATF is what to use in MN6.
Who's:
Brand depends on preference, but I replaced mine with Amsoil.
How:
Draining is easy as draining the oil except the drain plug is horizontal so is squirts out sideways...yuck! To fill, get ~4 feet of 1/2" clear tubbing at hardware store. Have one person hold the tube in the fill hole, and another person pour the fluid into the tube held above and to the side of the car until it starts coming out the fill hole. Button it up. Be sure to do this with the car level or you wont get enough or too much in. Raise both ends if neccessary. I actually did this in less time that it takes me to change the oil.
Who's:
How:
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I switched to Moble 1 synthitic in my 98 and 02 ZO6 and WOW what a difference. It shifts very smooth and does not have that notchey feel when shifting. I am VERY satisfied with the switch!
When you change your fluid, if you go to your local autoparts store and purchase one of the trans fluid bags (it's sort of like an IV bag) it will make re-filling the trans a snap!!! All you have to do is pour 2 qts of fluid into the bag and squeese it in to the fill hole
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
Good post!! There was a seminar with Dave McClellan and he said that synthetic is the way to go for all fluids. He said it handles the heat much better than dino oil. So I can't understand why JTS97Z28 above had a hard time. Unless the damage was already done and the synthetic showed the faults. I will be changing all my fluids to synthetic this winter. Much better anti-wear with the synthetics. My .02
thanks for the posts guys
Dan
As per others who previously replied, you are fine with Mobil-1 Synth ATF since it meets the Dexron III requirements. I switched out my non-synthetic factory fill with Redline D4ATF Synthetic over a year ago and have had no problems. There are several synthetic alternatives to Dexron III that are fine to use.
Well go ahead and switch but im telling you that the sychros and blocker rings do not like the synthetic fluids.
Here are a few quotes from my friends over at the f-body boards:
"You do not want to use synthetic oil in your transmission. They need slight friction to work and function properly and synthetic oil is just to slick for it. I have never heard of any transmission shop that used or recommended synthetic oil. If fact when I asked they said "Oh no....no synthetics, use regular oil." They recommended Penzoil ATF Dextron III. Thats what I use now. There are a few transmission builders in here that will tell you the same."
"in a six speed situation you only wanna run dexron III NON SYNTHETIC!! i personally run the valvoiline dexron III non synthetic in my M6 only cause i cant find any mobil 1 non synthetic ATF fluid"
"synthetic is a friction modifier and the m6 tranny syncros work on friction so you do the math"
"As far as synthetic, I stand by what I've said: it doesn't help anything, and the slippery characteristics are not conducive to synchros working properly."
"The lubricity of synthetic is a bit better than non-synth, and reducing friction between friction surface and the surface on the gear is not a good thing for synchros."
"Chuck, It's a FACT that the 98-00 tranny's came with paper fiber blocker rings. One thing you have not counted on is that some of these 98-00 trannys have been rebuilt or had those blocker rings replaced with the carbon fiber upgrades.It has come from people in the profession that the synthetics DO break down the paper fibers more quickly."
Well I can go on and on, but if you seriously want to use Synthetics in your tranny so be it. I used Mobile one synth ATF in my T-56 and will NEVER again use a synthetic fluid in the tranny.
Hope this helps.
JT
Hope this helps.
JT
Premium Supporting Vendor
AMSOIL synthetic ATF meets Dexron III requirements and is what I use in my tranny which sees pretty rough duty (16k total miles, 8 DE days, and 24 SCCA races and counting...).
AMSOIL ATF Product Info
AMSOIL sales through my dealership benefit my race team and this site. Thanks for your support.
Buy AMSOIL at Wholesale
AMSOIL Preferred Customer Program allows you to buy any AMSOIL product at wholesale, which is about 15-20% less expensive than retail. Cost is $10 per six months and you can buy as much oil as you want during that six months. To sign up, all it takes is one phone call to 1-800-777-7094. Give them reference number 1206638.
Or you can use this link:
Again, please put 1206638 in the customer number block.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Ordering Information (Retail sales using reference #1206638 benefit the forum.)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
AMSOIL Catalog
AMSOIL Catalog
