What is the oil drain plug size to remove oil plug in pan?
Old 10-21-2004, 04:47 PM
LS WON
LS WON's Avatar
Default What is the oil drain plug size to remove oil plug in pan?
What size wrench is needed to remove oil plug and are the stock C-6 oil plugs magnetic if not are there any magnetic oil plugs available for the C-6?
Old 10-21-2004, 05:08 PM
hb_cpa
hb_cpa's Avatar
St. Jude Contributor
1. 13MM
2. Don't believe so
3. Yes
Old 10-21-2004, 05:11 PM
LS WON
LS WON's Avatar
Originally Posted by hb_cpa
1. 13MM
2. Don't believe so
3. Yes
Thank you
Old 10-21-2004, 05:31 PM
hb_cpa
hb_cpa's Avatar
Magnetic Plug $2.06
Fichtner Chevrolet
Old 10-22-2004, 01:20 AM
LS WON
LS WON's Avatar
Magnetic Plug $2.06
Fichtner Chevrolet
Thanks again for the info I will have to get one and I hope they haven't made oil changing in a C-6 a pain. It will be ditto for the auto trans, and differential in the future also. Get proper sizes and tools. I would prefer to do alot of this stuff by myself if I don't have to break my back rather than spend a fortune for the dealer to keep my car all day.
Old 10-22-2004, 05:36 PM
C8-Vette
C8-Vette's Avatar
Pick up a FRAM Sure Drain Model SD-4 About $13.00-any auto store Never have to worry about removing plug and pain of the *** gasket-Takes 1 minute to install .Worth every penny!!!
Old 10-26-2004, 10:01 AM
docrings1
docrings1's Avatar
C6 FAQ Master
$1.89 Make you own magnetic drain plug:
https://www.corvetteforum.com/techti...D=40&TopicID=5
Radio Shack Magnets
Old 10-26-2004, 03:01 PM
LS WON
LS WON's Avatar
Then it wouldn't be factory stock and I would feel like I am doing a butcher job going to that extent. I don't have confidence in that system yet. I'll stick with the magnetic plug thanks...
Old 10-26-2004, 04:32 PM
C8-Vette
C8-Vette's Avatar
Got 4 cars with Sure Drains --Never a problem!!! Been on my cars for years.
Are you familiar with the FRAM product??
Old 10-26-2004, 05:49 PM
LS WON
LS WON's Avatar
I have heard of this about a year ago but have not heard of it since as it hasn't been too popular around here. Feel free to fill me in
Old 10-28-2004, 07:17 AM
C8-Vette
C8-Vette's Avatar
Sure Drain supplies you with a plug that replaces the factory plug.The new plug releases oil when the hose attachment supplied is inserted.
Fool proof and safe .It not even noticeable. Go to your local auto store and check it out. The biggest problem with factory plug is the gasket-never seem to have one in stock(not that is has to be changed every time)
To What is the oil drain plug size to remove oil plug in pan?
Quick Reply: What is the oil drain plug size to remove oil plug in pan?
