Stock Z06 makes 606rwhp at TT Performance
My dream has finally come true. I took the plunge. My bone stock 2002 T/R Z06 with nothing more then a hurst shifter and 17,303 miles on the clock, went to TT Performance for a make over. Mods... P-1sc blower kit, racetronic's pump, 42 # injectors, Kooks 1-7/8 LT, with an off road "X". Everything else is stock. Springs, pushrods, bottom end, TI exhaust, gearing right down to my original F-1's. Right out of the box it made 540rwhp-485rwtq, after 3 more pulls and more fuel we ended up with 606.53rwhp, 513.22rwtq. These are SAE, NOT UNCORRECTED. I don't know how to attach my sheet, but here is the link to www.ttperformance.net/dyno/ttp1.bmp My A/F at the end got lean because at 606rwhp, on a P-1 and only 42#'s of injector, we ran out of injector. If I had 57#, no telling... Timing is modest, never came close to the computer knock sensor. Ran on 93 pump gas.
At this point it started to rain outside, so the test drive was out of the question. I have to wait until Monday. I can wait... I'm dying...
I have to tip my hat and give all my thanks to Matt S, George B, and Nick at TT Performance. They have been a force for "F" bodys for some time, and now have shown there skills and tallents in the Vette arena. I have never seen anyone tune like George and Matt, (the Propritery tune of TTP is what is making the difference.) I also must thank Andy at AandA. The bracket is another key to this success. We made 8 to 9# of boost on every run, NO BELT SLIP, NO DUST, with a 6 rib belt.
I will post more after the test ride
Originally Posted by Red C5
Nice numbers. Isn't that a little too lean for a blower car through the entire rpm range?
Mark
I am impressed with the power!!
But man thats ALOT of power for stock internals. Maybe a little too much?
I never doubted prochargers couldnt make big power. I just thought on a zo6 550rwhp is about all you want to go because of the stock pistons and rods.
1) What was my manifold temp?
2) What were the atmospheric conditions that day?
3) What was timing set at?
4) What were the timing map perameters/configurations?
5) Octane?
6) Water temp?
7) Style of intercooler?
With these questions answered, then lets look at your original question and see if it has not been answered..
IMHO..I believe you have to be aware of the weather conditions, and have a good tune. (this goes hand and hand) Saturaday night, we ran a strong 606rwhp. We never bounced the knock sensor, there was NO DETONATION...The motor had more, we ran out of injector. Even the Z06 springs pulled flawlessly to 6400 and 9#'s, no float. Don't trade in your springs too fast gang.
My weak link now is not the bottom end, its probally the clutch. Then again I am not putting slicks on the car just yet, so the F-1's are the weak link.
Originally Posted by mdhmi
That concern was brought up by other members in http://forums.corvetteforum.com/showthread.php?t=927248.
Mark
Mark
Just for reference I installed a D1 on a 02 Z06 and it made the same amount of hp with about the same tune (12.7, MMS Tune). I think it blew up. If I remember right Andy was putting a new motor in it..I could be wrong about it blowing up. It did make the same hp though.
There are no shortage of stock motors that have been grenaded by running too much timing and too little fuel or just too much power on stock internals. I'm not saying ForcedFed is going to have problems, but sometimes all it takes is a bad tank of fuel.
Cheers,
Mark
Cheers,
Mark
The numbers are fantastic when viewed in a vacuum. Come on tho. You listed all the reasons why the HP was so high. I hope the temp outside never goes above your test date scenario. Or that you never get bad gas. on and on. In a perfect world, you've got a monster car. On a bad day you'll have a kit car.
You'd have to assume the tuners are brighter and more inventive than Andy who has developed this kit and IMO perfected it. I assume Andy has trashed a few engines getting to the point he is at with this setup and never grabbed the 600hp level at least for long. In fact I'd like to hear from Andy on this but that would be pitting tuners agianst each other and that won't fly.
Again, time will tell.
Good luck with it.
I always knew this pic would come in handy.
Originally Posted by drcoffee
Don't go there. They're kinda touchy on the subject.
Good luck with it.
Good luck with it.
I do not mind constructive criticism and questions, but really... Your comments are argumentative and inflammatory. They serve no purpose. Nothing has been gained or learned from them for the exception of how to start an argument.
All in all, your comments make you sound jealous. Others can achieve what YOU cannot.
Great numbers
but good tune/bad tune either way its just a matter of time for your motor to let go with that much power on stock internals.
Jon
Jon
