Bose System Speaker replacement
My Center Speaker (Infinity 3.5 REF3002CF) Blew
It was definitely NOT from too much power but too little. So I took the extra I had out of the box and hooked it up. I made sure I had the Pos and Neg connections right first.
When I turned the stereo up to about 3/4 volume I could here the new one start to crackle a bit.
Any comments or suggestions? I guess the Infinity REF3002CF's are not the best for the Bose Amp.
Here is the web site for them.
http://www.infinitysystems.com/carau...er=REF&Cat=MEL
It seems this thread has been blown apart in the last move. So here is the original text that I had used to start this thread:
Well I did it, Replaced the 3.5" in the door and the 5.25" in the back. And am I happy. XM is now clean and crisp, I can hear the snare loud an clear, the symbols are back, I am hearing stuff I haven't heard in songs I know and like. I had to turn down the treble for the CD, which for my ears is saying something.
Blow by blow.
The speakers: Eclipse SE8233 3.5" coaxial and SE8353 5.25" triaxial. They each measure 3.4 ohms and exactly matched the Bose (3.4 ohms)I took out.
Installation.
Removing the rear covers is pretty straight forward, First prop up the hatch so that there is no tension on the lifts, With a screwdriver you can move the spring clip and the lift will pop off the ball. Then there are 4 plastic pins the need to be popped out. then just pull out the cover out from the bottom. Remove the speakers, Connect the new speakers (I won't go into that, you have to make the plugs work) and then bolt them back in. Cake x 2. Black is ground in the rear and green is ground in the front.
Front doors:
Driver side, remove the small oval panel under the handle and there are two torx screws, then the panel pulls straight off, starting at the bottom, there is a place to pry on the bottom to get started. then the panel will make a ton of noise as you continue to pull. Just replace the speakers (wiring again) and replace the panel and the little cover.
Passenger side, the screws are in a different place, one is behind the door release button(just pull the aluminum cover straight off) and the other is under the armrest(just a hole)
Note: before you tighten the screws close the door and make sure the panel lines up, if not there is a bit of movement available(very little) align and tighten.
Took me about 1.5 hours, because I was being extra cautious learning how the rear panels came off. The result was pretty amazing. I spent about $160 for the speakers. I had done my homework and listened to many different speakers and the Eclipses were by far the brightest, and that is what the Bose lacked. Bose and their paper speakers Believe me boys and girls there is nothing special about the Bose Installation, there is no enclosure for the rears, just a plastic square bracket. The C4 Bose had enclosures and amps. The fronts are nothing special, the speaker is just screwed to the panel and there is no enclosure there either. Standard old paper 4 ohm speakers.
Blow by blow.
Installation.
Front doors:
It's 3.5
Check out the web site in the link above. It most definitely is the amp. I don't think the Speaker can handle power or lack there of that the bose amp is putting out.
I guess the Infinity speakers are not good replacements for the C6 Bose system.
Originally Posted by SouthFlorida
Human nature is a funny thing sometimes. How people will be defensive of something and can’t see the obvious just because they are connected to it by ownership, etc. I love my C6, it is an amazing automobile, but the speakers are total and absolute junk, and anyone who says they aren't, is delusional or they have been listening to twenty year old transistor radios to long.
Premium Supporting Vendor
Location: www.EXOTICVETTE.com - FL Cruise-In VI, VII, & VIII
Cruise-In V Veteran
St. Jude's Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Originally Posted by LS WON
Are there 7 speakers? Also on my stereo speakers it doesn't say BOSE on it like some other speakers I have seen in the C-6.
J/K - Yes, the C6 system is better than the C5. For the average Vette driver (is there such a thing???) upgrading the speakers and adding a sub to the system will be more than enough - my .02
BTW, I didn't realize it had a center speaker either!
HAPPY WEEKEND!
hazy (09-01-2022)
CI-7-8-9-10 Veteran
Cruise-In IX AutoX Winner
St. Jude Donor '05-'06-'07-'08-'09-'10-'11,'19,'22
St. Jude/CI Name Tag Designer
Originally Posted by Eddy C
Switching regularly between the Vette and my wife's Lexus with the Mark Levinson, there's no denying the difference. You don't have to be a sound expert or have acute hearing to think...yeah, this is good, but that is REALLY good.
The Mark Levinson in my '02 GS430 totally rocked. The Nav Sound system in my C6 totally blows. BUT, the GS couldn't get out of it's own way compared to the C6 in performance. Guess everything has goods and bads.
We have a winner! Longest dead thread brought back to life!
Alot has changed since then. Many have swapped out the fronts. Myself included. JL 6.5 components. I supplemented the bass with a JL Stealthbox subwoofer. try the audio section for good ideas and knowledeable help.
Drivers side tweeter....
My C6 driver's side tweeter doesn't "kick-in" until I re-balance the volume all the way to "Left" and then increase the volume - at which time the drivers tweeter kicks in. Is this typically a speaker problem, a wiring problem an electronics problem? I'm all ready to swap-out the speaker, but don't want to pull apart the door unless I know in advance that's what needs to be done. Everything else (all other speakers) seem to work fine, making me think it just may be the 3.5" tweeter. Again, have others had a similar issue with this speaker?
You must have gotten the 'Radio Shack' speaker system It's an upgrade from the Bose system
HAPPY WEEKEND!
HAPPY WEEKEND!
