C6 Octane Requirements ?
Old 10-14-2004, 11:44 AM
sjLt1
sjLt1's Avatar
Default C6 Octane Requirements ?
What type of gas are you C6 owners using ? Regular or premium(93 or 94 octane) ?
What does the owners manual stipulate ?
sjLt1 is offline
Old 10-14-2004, 12:13 PM
Runesabre
Runesabre's Avatar
What stations provide 94 octane? I've been trying to find one but all the ones in my area (Chevron, Exxon, Citgo, Shell) only offer 93 octane.
Runesabre is offline
Old 10-14-2004, 12:16 PM
hanbitxpilsung
hanbitxpilsung's Avatar
is there even much of a difference between 94 and 93 octane?...
hanbitxpilsung is offline
Old 10-14-2004, 12:17 PM
slowtrak
slowtrak's Avatar
Owner's manual says 91 octane and above . It says the car's computer will adjust the timing to run on regular or mid-range to prevent knocking but not to make a habit of it .
slowtrak is offline
Vette_DD
Support Corvetteforum!
Vette_DD's Avatar
Received 1,276 Likes on 935 Posts
I'm using BP/AMOCO, premium, 93 octane.
The owner's manual says to "Use premium unleaded gasoline with a posted octane of 91 or higher for best performance." But it also says you may use lower octane gasoline, but your vehicle's acceleration may be reduced.
It says that if you use gasoline with a lower than 87 octane rating, you may get a heavy knocking noise when driving. If you use gasoline with an octane rating lower than 87, it recommends that you use 87 or higher as soon as possible.
There's also a full paragraph on California gasoline and California emission standards.
Vette_DD is offline
Old 10-14-2004, 12:18 PM
sjLt1
sjLt1's Avatar
In the MI area Sunocco carries 93 & 94 octane.
sjLt1 is offline
Old 10-14-2004, 12:37 PM
7 OUT
7 OUT's Avatar
91 Octane is the highest we have in Colorado. Since, the altitude is higher, you don't need as high of an octane gas. I certainly hope 91 is high enough.
7 OUT is offline
Old 10-14-2004, 06:53 PM
Evil-Twin
Evil-Twin's Avatar
Received 3,812 Likes on 1,925 Posts
St. Jude Donor '03-'04
with 10.9:1 compression 93 octane will work the Ls1 with 10.5:1 compression is having problems with 91 octane.. especially in the summer..
Evil-Twin is offline
Old 10-14-2004, 11:00 PM
Dsob15
Dsob15's Avatar
Would it be better if I ran higher than 93 or 94 octane in my C6?
Dsob15 is offline
Old 10-15-2004, 12:27 PM
rbl
rbl's Avatar
no 87 is fine
rbl is offline
Old 10-15-2004, 12:32 PM
rbl
rbl's Avatar
The above information is correct.
I have now tried 87 and 93 in the C6. I can not tell ANY difference in performance and the mileage is the same. I have ~1150 miles on it now.
I got exactly the same results in the 04 coupe.
This is an emotional issue -- well discussed.
However, I do use 93 when I go to the track.
rbl is offline
Old 10-15-2004, 02:01 PM
vetterun
vetterun's Avatar
Exactly which of the statements made by RedC6Coupe you quoted is "incorrect"? They were all either a statement made about what he/she uses, or quotes and summaries from the owners manual. The warning in the owners manual refers to using fuel with less than 87 octane rating - have you used that also?
vetterun is offline
Old 10-16-2004, 01:55 PM
rbl
rbl's Avatar
You having a bad hair day dude or can't you read?
Probably just can't read ... and you are "incorrect" ... not RedC6Coupe.
rbl is offline
Old 02-06-2011, 10:32 AM
Augustus_Maximus
Augustus_Maximus's Avatar
Bump for a update .......
A.
Augustus_Maximus is offline
Old 02-06-2011, 01:09 PM
Grumpy
MONARTOR
Grumpy's Avatar
Location: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09-10-'11-12-'13-'14-'15-'16-17-'18-'19'-20-'21-'22-'23-'24
A.
not needed
Grumpy is online now
To C6 Octane Requirements ?
Quick Reply: C6 Octane Requirements ?
