VNM BackBone
VNM BackBone
Technical Data and hard Facts on the Backbone...
1/8" 304 Stainless Steel
Ceramic Coated with 1400 Degree F Black Matte color
Weight 12 3/4 Lbs
Resonance tested On Car in operation By Forum Member/Mechanic
Before install (Stock Plate) 23 Hrtz
After install (Backbone) 21 Hrtz
Nasa Factor of Safety Tested Cosmos Software
(Scale 1-100 worst to best)
Compression and Strength @ 1500 PSI applied to sides and flat surfaces
BackBone
FOS of 21.95
vs;
1/4" 6061
FOS of 6.09
Thermal Tested Console temp infrared heat thermometor ambient temp of day was 80 degrees
Prior to install 99 degrees 1 hour Run/Drive time
After install 73 Degrees 1 hour Run/Drive time
Seat of Pants testing excellent improvement in Drivability and customer Satisfaction.
These are our test results and provided info on the Backbone for all to see. Thanks to all who have assisted and provided results.
VNM Performance (800)979-4866 www.vettesnmore.com
IN STOCK and Available for immediate shipping.
Weight 12 3/4 Lbs
BackBone
FOS of 21.95
vs;
1/4" 6061
FOS of 6.09
Originally Posted by Elite Engineering
You know this is just going to start another Aluminum vs. Stainless Steel debate.
Where is Brian from bttech?….
[QUOTE=30yeardream] Technical Data and hard Facts on the Backbone...
Does this absorb, deflect, or dissipate the heat?
[QUOTE=30yeardream] Weight 12 3/4 Lbs
What doe the stock piece weigh?
[QUOTE=30yeardream] Resonance tested On Car in operation By Forum Member/Mechanic
How was that done? There are several methods but many factors change the resonances by various amounts such as temperature, dimensions, heat treatment etc. And, after all is said and done, what would a 2 hertz change be comparable to? Like stiffer sway bars?
[QUOTE=30yeardream] Nasa Factor of Safety Tested Cosmos Software
BackBone
FOS of 21.95
vs;
1/4" 6061
FOS of 6.09
What does this mean in the application sense of this product? I mean, will even the lowest number withstand a launch into outer space without failure - or does this indicate that after 100 cycles the material takes a "set" and is permanently distorted
[QUOTE=30yeardream] Thermal Tested Console temp infrared heat thermometor ambient temp of day was 80 degrees
Wow, this alone makes it worth it!
Can you quantify this somehow? Have you tried, as an example, jacking behind the left front tire and measuring the distance delta before the rear tire raises – or better a diagonal distance or weight measurement?
Sorry to ask so many questions...
BackBone
FOS of 21.95
vs;
1/4" 6061
FOS of 6.09
Originally Posted by 30yeardream
[B]Seat of Pants testing excellent improvement in Drivability and customer Satisfaction.
Originally Posted by sempi
Sorry, this is not final until you do the SAME testing on the aluminum part and post the results. You are only half-baked.
Sempi
Sempi
I do not offer the aluminum nor will I.... Therefore these are my Final results for my Plate. My results are information only for the VNM Backbone If you desire to get info on the competitors then contact them. As I have always stated all of these plates weather Aluminum or S/S work as described and I dont percieve to make any further claims above what my testing results on The BackBone reveal. If there is an Independant person or persons who want to make comparitive testing side by side then please be my guest. The rsonance has a baseline now so if there is a person with the Aluminum plate installed in the Conneticutt area they should see the mechanic who did the testing for a comparison. I offer only The VNM product.
I'm sitting on the fence on this one for now!!
Supporting Vendor
St. jude Donor '14
Originally Posted by don527
i see vnm mentioned alot but dont see any pics or link. if there is a website, can something pm it to me.
Okay, that's IT!
I'm putting gray pinstripes on our plate
We have Backbones in stock. Thanks to all who have purchased. We will continue to provide great customer service and fast shipping to all. Thanks
I think someone should offer them made of the same tiles that are on the space shuttle. Just kidding, I have seen the VNM piece first hand and the quality is top notch, a very nice piece. Sorry just my .02
