1SB package homelink transmitter
Old 10-01-2004, 12:28 AM
clem zahrobsky
clem zahrobsky's Avatar
Cruise-In I Veteran
Cruise-In II Veteran
Default 1SB package homelink transmitter
anyone else get the 1SB and did not get the homelink transmitter in the visor?????
Old 10-01-2004, 12:43 AM
Another Yellow
Another Yellow's Avatar
St. Jude '03-'04-'05-'06
Clem, you've got to be kidding! They forgot to put the homelink in your car?
Early build error, hopefully easy to correct.
Old 10-01-2004, 01:10 AM
clem zahrobsky
Cruise-In I Veteran
yep no homelink
Old 10-01-2004, 02:27 AM
Joezone914
Joezone914's Avatar
I read a post 2 or 3 weeks ago same problem!
Old 10-01-2004, 07:01 AM
bramwellt
bramwellt's Avatar
unfortunately, this isn't the first I've heard of this... IN-SANE! I don't think that would be an easy one to remedy either... I guess it all depends on if the wiring is already run for it or not... They're not battery operated are they?
Old 10-01-2004, 07:24 AM
TRAYC7
Support Corvetteforum!
TRAYC7's Avatar
NCM Ambassador
CI-3-4, 9 & 10 Car Show Winner
CI-3-4-5-6-7-8-9-10 Veteran
St. Jude Donor '04-'05-'06-'07-'08-'09-'10,'14, '16
St Jude Fedex Bowl Donor '09
If it is similar to how you added the homelink visor to the C5.. its not that big of deal... simple addition...
Old 10-01-2004, 08:13 AM
bramwellt
bramwellt's Avatar
That's cool... hopefully their dealer can get these ordered in short order. Good luck to those missing them!
Old 10-01-2004, 08:24 AM
StanNH
StanNH's Avatar
Received 1,222 Likes on 412 Posts
It is pre-wired. I originally was going to order a 1SA package but wanted Homelink. The dealer checked and said they could just order the part and install it there since the wiring was all there. I wound up going with 1SB so I didn't have to do that, but it's a simple installation and requires no modifications to the car.
Stan
Old 10-01-2004, 10:32 PM
NextOne
NextOne's Avatar
Received 1,046 Likes on 645 Posts
I posted a month ago that my car was also missing the Homelink transmitter. The dealer checked with Chevy and found out that this happened to several cars. I have VIN# 01338. So, they've ordered a replacement visor and the part has arrived. Now I'm just waiting to find a time to take this in to the dealer for the swap. I'm glad to read that it should be a swap out and that all the wiring is in place. This is the ONLY fault I have found with the car.
Old 10-01-2004, 10:37 PM
jschindler
jschindler's Avatar
I bought a Z28 in 1997 that was delivered without the standard equipment fog lights. I had the car several days before I noticed. I guess they just run out of parts, and someone on the line just laughs about it!
Old 10-02-2004, 01:41 AM
clem zahrobsky
Cruise-In I Veteran
my vin is 1359
To 1SB package homelink transmitter
Quick Reply: 1SB package homelink transmitter
