Closing the hatch on the coupe
What method are you guys using to close the back hatch? Are you tossing it down with some speed as you would the C5 hatch, putting it down softly and then pushing down to engage the pull down, etc.?
I normally prefer to just put mine down softly and then give the glass a little push to engage the pull down but I'm finding that it doesn't work properly that way most of the time (but it does sometimes). About 1/3 of the time it works that way but 2/3 of the time when you push down, it just catches the first latch and doesn't pull down. As a result, I've been just slamming it as if it had no pull down mechanism and that seems to work.
Is this normal?
Mike
Is this normal?
Mike
Location: All of the true things that I am about to tell you are shameless lies. --Bokonon
St. Jude Donor '04-'05-'07
Is this normal?
Mike
Is this normal?
Mike
In my C5, I always leave the driver's door open before closing the hatch as I never want to slam it with tons of force. With the introduction of the latch system in the C6, I was hoping the "leave doors open while closing hatch" days would be a thing of the past. If the mechanism is not working consistently, you should report this as a problem so that it either (1) gets corrected via an adjustment, if that's possible or (2) engineered correctly by GM in subsequent builds/model years.
Originally Posted by Bryan
Isn't it motorized to "suck" it closed now? The one I saw at the dealer had that.
lock engages.
Originally Posted by RedC6Coupe
You have to get it close enough to the latch for this to take effect.
Mike
Originally Posted by abrimberry
I feel like I should be demoted from "senior member" to "noob" after that one... but thanks! That's the way I've been doing it, but since it works intermittently if you close it softly and then press down, I was just wondering how it was designed to be operated.
Mike
GM really should have included a chapter on "operating the hatches and doors" so as to eliminate all this confusion.
I think the reason they eliminated the door handles was so they wouldn't have to deal with so many questions as "what is the best method for operating the door handles?"
out of the 20 or so times i've closed mine, only about twice did it engage itself and finish pulling it down tight.....
still haven't figured out what the trick is to get it to work each time...or if it's a problem that needs fixing
Originally Posted by Corey_68
Please tell me this post is a joke.
I slowly and carefuly close the hatch and leave it where it is just about to engage the latch.
Next I take a 4-5 steps back and in one big leap launch myself onto the glass slamming it shut.
Works every time.
Works every time.
Works every time.
Works every time.
