F55 completely inoperable in my C6 coupe
The server crashed when I posted this thread a minute ago...here's another try:
Since I've had my C6 for a few days now (two, to be exact!) I thought I'd share some major issues with my car.
First, the good...for the most part it's AWESOME!!!! I LOVE driving this car. Compared with my bone stock C5, the differences are dramatic.
The bad news...
1. The F55 is completely inoperable. After 850 miles of driving on rough roads, smooth roads, wavy roads, and curvy roads (the Tail Of The Dragon), there is absolutely no discernable difference between the Tour and Sport modes. I checked, and the spacers were removed from the car during prep.
2. The left front speaker in the door panel has a buzz which is similar to a broken voice coil. I don't detect it in the rear speaker, so I don't think it's the amp...probably a defective voice coil or connections.
3. The orange peel is atrocious on all horizontal surfaces. On the entire rear fascia and much of the front fascia, it's even worse. I'm going to ask for a repaint. Wish me luck!
Any suggestions as to how I can get these problems fixed would be appreciated! Thank you!
The bad news...
For sure I'd get my dealer to fix both 1. and 2. ASAP. Don't know what to suggest for no. 3. Haven't been keeping up with how & where everone got their car, but did you look at the paint job at all when you picked it up? Not sure what your recourse is if you didn't mention it at the time.
Originally Posted by ZippoMan
What causes orange peel? The C6s I looked at this weekend had some terrible orange peel.
Originally Posted by TedG
The first 2 are simple warranty issues.
The third may just be a fine sanding and buffing. It is what should be tried first.
Originally Posted by sorka
My understanding with the C5 is that he OP was caused due to static electricity build up which is far far worse on the plastic panels.
That would certainly explain why it's noticably worse on the front/rear composite panels! I hadn't heard that until now, thanks!
Originally Posted by prseasix
Thanks, Ted! Is this something that the local yokel dealership can do, or do I need to drive to a bigger city/larger dealership?
I also have the F55 and can't feel any difference between Tour and Sport. Wonder what we should feel? I will try to contact some folks I know and see if they can describe what the difference should be.
Tom E
Brea,
Tom E
Brea,
Any decent body shop can do it. I am actually quite good at it, mostly it is a matter of the proper buffer, foam pads, and the proper compound and of course some 1000-2500 grit wet or dry paper. So if I can do it, most anybody can.
Is there a clear coat on the C6? If so, after you do the sanding, do you have to reapply the clear coat? And, do you recommend sanding it wet or dry?
Yes there is a clear coat on the C6. I must be wet sanded with a small amout of dishwashing soap in the water. All that is done it the high spots are taken down to the low. You don't go through the clearcoat. Most orange peel is only a very slight varience is height between the high and low spots. Usually only a few strokes with 2500 grit paper will render it smooth and ready for buffing.The buffing take almost no material especially if you use foam pads. It actually slightly melts the surface and it flows back to a shine.
Tom E
Brea,
Tom E
Brea,
It's as if my car were permanently locked into the "Sport" mode...the ride is very rough, and the suspension/steering feel very tight, almost suitable for autocross...
Tom E
Brea,
Tom E
Brea,
St. Jude '03-'04-'05-'06
I also have the F55 and can't feel any difference between Tour and Sport......
Cruise-In I Veteran
Cruise-In II Veteran
The bad news...
The bad news...
