Saw a C6 race at Englishtown
Old 09-04-2004, 08:08 PM
Geneus
Geneus's Avatar
Default Saw a C6 race at Englishtown
Dave Busch, from Cartek, brought his virgin C6 coupe to the Corvette Challenge today and made a few runs on the 1/4 mile. Most of the run's I saw were around 13.4's, though bear in mind that the surface was hot and the DA was poor (~2000?). I also think that Dave was still getting use to the shifter in this new car.
Old 09-04-2004, 08:44 PM
kh24
kh24's Avatar
The best they got out of it was a 13.1@109. Still needs to be broken in a little and some cooler air would really help with the ET.
Old 09-04-2004, 09:23 PM
The DBK
The DBK's Avatar
Man, that's disappointing. 109? Eh, oh well, it is still hot and the car is new.
Old 09-04-2004, 09:36 PM
Dave_Busch
Dave_Busch's Avatar
The race weight was 3450. The torque management is bad. I had a lot of problems trying to do a burn out. Yes the traction control was turned off. It still drives like it is on.
Old 09-05-2004, 12:38 AM
rbartick
rbartick's Avatar
Location: Admit Nothing, Deny Everything, Make Counter Accusations.
Dave & Julio,
Here are two pictures of your new car:
http://www.rbartick.com/cf/cartek_c6_1.jpg
http://www.rbartick.com/cf/cartek_c6_2.jpg
Old 09-05-2004, 03:36 AM
ph3n0m73
ph3n0m73's Avatar
Has anyone else gotten a faster time at the track yet?-- with a C6 obviously?
Old 09-05-2004, 12:09 PM
PRNDL
PRNDL's Avatar
here is a clear shot of car AND DRIVER!
Old 09-05-2004, 02:46 PM
Cobra4B
Cobra4B's Avatar
CI 3-5-6-7-8 Veteran
Nice ride =) time for the X package Can you tune that torque management crap out?
Old 09-05-2004, 03:45 PM
los7883
los7883's Avatar
Hopefully it won't be long before we start seeing some packages for the C6...
Old 09-05-2004, 03:52 PM
PRNDL
PRNDL's Avatar
Not to speak for Dave... but he did mention that they (Cartek) already have an electronic module to bypass it (obviously not yet installed in this car). I wonder how big of an issue this will be for the average C6 driver who doesn't want to mod his car but wants to occasionally run at the dragstrip.
Old 09-05-2004, 07:58 PM
Cobra4B
Cobra4B's Avatar
Uhhh... it's the same basic motor as the ls1/ls6 so the heads and cams out right now will all bolt up, but just to a 6.0 block.
Old 09-05-2004, 09:57 PM
los7883
los7883's Avatar
So just the bore/stroke are different? It will still be a while before a catback system is ready for it, looks like there may be a set of headers out right now that fit it, "LS2 Edit" still isn't available yet...are the intake and the throttle body the same? What about the drivetrain? I would think it is a little different. The suspension may be different as well...hmmm...but if you say they're the same...
Old 09-06-2004, 12:49 AM
Cobra4B
Cobra4B's Avatar
All they did is bore it out to a even 6.0... same as the 6.0 chevy truck motor. The heads are polished ls6 heads, the cam is the same spec as my '01 Z06 and the intake manifold has been upgraded to use a 90mm throttle-body.
Old 09-06-2004, 11:45 AM
Daryl
Daryl's Avatar
Old 09-06-2004, 11:53 AM
dads01dream
dads01dream's Avatar
So they have torque management on a 6sp? I thought it was only on the A4's?
Old 09-06-2004, 04:36 PM
REDGAR
REDGAR's Avatar
Cruise-In II & IV Veteran
CI VI Drag Champ!
Next best thing to being there....video
http://www.challengevideos.com/2004/...09-04-B_07.wmv
http://www.challengevideos.com/2004/...09-04-B_08.wmv
Old 09-06-2004, 05:14 PM
Dave_Busch
Dave_Busch's Avatar
There are a lot of changes to the engine. Just about all the sensors have been moved. This will affect which parts will work and which won't. We will be going through every thing to find out.
Yes there is torque management on 6spd cars. Any one that has tuned with edit can tell you about all the different tables. There is almost no difference in performance with the traction control turned off! We will be testing a module that will eliminate it.
To Saw a C6 race at Englishtown
Old 09-06-2004, 07:10 PM
racelance
racelance's Avatar
St. Jude Donor '09
I ran the 2005 Carlisle Callaway Corvette Project car this weekend at Beech Bend raceway this weekend at the best time we got was a 13.0 at 109 mph - totally stock. We will be running the car at the drags up here in CT this week again for another baseline run. I'll keep you posted if we break the 13 barrier.
Lance
Old 09-06-2004, 07:54 PM
dads01dream
Hey Lance,
Where's there a 1/4 mile track to run the car in CT??
Thanks Dave for the info about TM, looking forward to seeing how you guys really wake-up that C6.
Old 09-06-2004, 09:49 PM
racelance
racelance's Avatar
St. Jude Donor '09
Originally Posted by dads01dream
Hey Lance,
I'm not certain where the track is located (I know there are 2 tracks - both approximately 1 1/2 hour away from Old Lyme). Trust me, I'm anxious to wake this car up! I test drove the Z06 Callaway today - it's running strong 11.3 @ 126 mph. I had a blast, now I'm ready for mine to "woken up"... he he.
Lance
Quick Reply: Saw a C6 race at Englishtown
