Should wheels be mounted with an Air gun ?
I am taking my car in for PA inspection. They are going to pull the wheels. When they go back on , should I tell them to torque them by hand or is the air gun ok ? What is the correct torque for wheels on my 98 ? thanks
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
No way baby!!! My dealer did this to me four different times. And after each time they replaced the lugs for me because they ruined the stainless steel covers on the lugs. And I put the replacements on myself. So it's a No No situation.
Originally Posted by Patches
No! They can damage your lug nuts, wheel studs, rotors or wheels. Should always tighten in 3 passes using 35, 70 and 100 ft. lbs. in a star pattern using a torque wrench.
No air tools!
No air tools!
That says it all!!!
No air tools!
No air tools!
Received 19,274 Likes
'20-'21-'22-'23-'24
Have them do it by hand. They need to use a torque wrench with a 19mm socket and progressively tighten the lug nuts down - first 60 lb/ft, then 80, finally 100.
Received 1,674 Likes
Originally Posted by StephenT
Get them torque them by hand.
You REALLY need to watch the guys with the impact guns. There are guns and compressors out there that are capable of 400 ft. lbs. A couple of years ago, I has a "cheesy garage" do a quick tire rotation on my "regular car". The guy put them on so tight that I actually bent a lug wrench trying to get one off. I'm a pretty big guy, and I could barely do it!
If you must have someone else pull your vette wheels, make sure that they hand-torque them!
Originally Posted by Dave1998
Is there any problem with them taking the lugs off with a gun? They are not chrome ? thanks
Robert
I use a gun on mine, but only after loosening by hand, then I spin em off with the gun to save time. For installation I start em by hand, spin em on with the gun until they just touch, then torque by hand....
No air tools!
No air tools!
I agree, I had to have my rotors replaced - they were all warped. Who do you think paid for this one?!
