Zeroshift: synchroless T-56, "Fastest shifting transmission"
Zeroshift,
What is the status on US availablilty?
Are there any Test mule results?
What about US Approved shops, anybody on board yet?
Thanks,
Ross
Thanks,
Ross
Originally Posted by nuke61
IMO, a VERY dissapointing post. You claim that ZeroShift in "nothing like one of those things (see below)." but when I did read below there was no technical information... it just sounded like marketing fluff. Are you SURE you're not using two clutches like the DSG, or high-speed automatic shifting like the Lamborghini?
gpflepsen, GM shortened the shifter handle length and modified the shift linkage a bit. Reviews I've read said it's nice enough that most people won't bother to get an aftermarket shifter, but it's not like it buttery smooth.
Also, the much respect Race Car Engineering ran a article on the Zeroshift, http://www.zeroshift.com/res/content...eering0204.pdf.
I for one would like to see the US availablility "RUSHED" and not put on the "back-burner"! 2006 seems WAY to slow to get this on our soil.
Ross
syncros are remove and your parts are installed - correct?
Originally Posted by gpflepsen
I'm talking about the C5R GTS racecar, the one you see on the track, not the one you buy at the dealership.
I have just read that they are using a new sequential gearbox, so that rules out C5R as a proving platform for Zeroshift. Man that would have been cool
The C5R uses a sequential shift racing gearbox (with dog engagement instead of synchros) so no clutch is needed for upshift/downshift. I'm sure there have integrated a n ignition cut on the upshifts and throttle blips on the downshift algorithms to help smooth things out and increae endurance for th long races. It used to be a Hewland box in years past.
It may all be moot when the new GM 6spd auto makes it way into the C6. Then you have the good ratio spread, full auto capability, and full tunability - with just a bit more parasitic loss. An LS7 would help on that end.
New article explaining indepth operation of the Zeroshift, but sadly still no transmission you can buy as of today.
June 2005 article - http://www.zeroshift.com/about/press.htm
