[UPDATE]HVAC Vacuum Issues (no progress)
Cruise-In III Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04
OK, I checked ALL vacuum connections (at least I think I did, could have missed something). ALL connections appear to be OK and no visible cracks in any lines. Line on back of manifold appears to be connected fine (there's only one, right?) ALL fuses appear to be OK. I got under the passenger dash and checked all those colored lines (vacuum lines) that plug into that unit (not sure the name) and they are all OK.
My AC is VERY cold, blower/fan is working but it blows equally hard out the vents, floor, and defrost no matter what setting I use on the controls.
Seems to me the "internal" vents/baffles (sp) are stuck in one position. I am CONFUSED. What is the next logical step? What is the next logical malfunctioning part? It has to be a vacuum issue, right?
I need a break...............why can't my car be perfect? It's not like I can't cool the car down but I want the controls to work when I select a mode....................
TIA
Keith
TIA
Keith
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I will take a look in the service manual later tonight and see what it recommends!
Look for a post late tonight!
Bill
Bill
Cruise-In V Veteran
Bill
Bill
Is the black vacuum line you refer to in the other thread look like a black wire? Very very thin in diameter? If it does, I cannot see that line in the back of the manifold.....so maybe that is missing and is my problem. Does that black wire looking line literally plug into the manifold? Or is just behind the manifold somewhere? I see the black rubber tubing that comes out of the manifold but it is larger and does not look like a black wire........it is about the diameter of a nickel or so......
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I have digital pictures of the vacuum line. I need you to e-mail me at:
bill327@msn.com so I can send them to you!!
Keith,
Have you ever had a battery replaced due to leaking, etc? Have you checked the vacuum lines under the battery? BTW, the thin black vacuum lines are nylon and kind of stiff. (They resemble about a 14 to 16 ga wire in size.) They are susceptible to battery acid damage. If you haven't done so already, just pull your R/F wheel off and then remove the small plastic close-out panel at the backside of the wheelwell. This will give you a good view under the battery. HTH
Robert
Robert
ac
on the drivers side just before the left actuator is the vacuum valve that controls the air direction that you are talking about also on the doors that open to change air flow on the outside where they come out of the case they have some little spring on them to keep them going in the right direction it could be alot of things it just depends on how bad you want to tear your car apart to find out what is wrong.
p.s. the doors inside the case are not the problem.
allan
allan
Cruise-In V Veteran
Originally Posted by LoneStarFRC
Keith,
Robert
Robert
Cruise-In V Veteran
I did send you an e-mail earlier from silvervette01@hotmail.com.....
Cruise-In V Veteran
allan
allan
a/c
the actuator is behind the dash on the drivers side of the a/c system don't take this the wrong way but if you don't have much mechanic experience you might not want to start taking the dash apart. and to find the vacuum lines they are talking about pull the battery out of the car and get a flash light and look in where the battery goes and towards the lower fender and door area you will see a valve and the vacuum lines.
Originally Posted by Buckmaster
Bill
you need to diagnose theproblem first. like I said in the other thread, drop the panel under the glove box and find the black wire, disconnect it at its connector near the manifold with all the colored vacuum tubes. Then apply vacuum to the manifold end of the line with a pump or your mouth, if things work with vacuum then the black line is your problem, if not, more troubleshooting.
Cruise-In V Veteran
Originally Posted by runamuk
The large vacuum line your talking about sounds like the one for the brake booster and the small nylon vacuum line should be right next to it, with the intake removed look around it should be right there, you ill need to reconnect this to the intake.
Since I had manifold work this seems to be the culprit......Thanks everyone for the help. BTW: I am somewhat mechanically inclined....just not re-building the motor and such
Cruise-In V Veteran
My manuals do NOT show where the black line plugs into the manifold This is killing me
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I'm going to lunch/dinner and when I get back I will get the mirror out and see if I can use it to take a DIGITAL picture of the fitting.
I do not know if it will work but i will try! Check back around 5-5:30 PM for a post from me!
Bill
Bill
I just went through this problem... Exactly the same symptoms as yours. My problem was the line coming out of the manifold. Since this is the source of all vacuum it is the first place to look. Also, since you had some work done on the manifold, that is the most likely place where a problem would exist. On the back of the manifold there is a big plastic fitting that plugs into the manifold and has the MAP sensor and a wiring harnnss/connector going into it. It also has a large diameter brake booster line plugged into this fitting. As part of this fitting there is a small vacuum port that points toward the passenger side. It has a 90 degree rubber vacuum connection coming out of it that points towards the firewall. The black plastic vacuum line, about 3/16" in diameter, plugs into this rubber connection. I have found that the black plastic line is sometimes too short and is easily pulled out of the 90 degree rubber fitting. In my case I had to use an extender line a couple of inches long to get enough length to not be pulled out.
From your discription I am 99% sure this is your problem.
This is very difficult location to work on with the mainfold in place. If you can remove the mainfold bolts and slide the manifold forward a few inches it will be easier to see and work on. Hope this helps and good luck.
Shirl
SDRE
Shirl
SDRE
At least you know what theproblem is, now you just have to plug the line back into the manifold as that appears to be your problems. I cut out the acid eaten part of my line and replaced it with some rubber vacuum hose and my HVAC is working correctly for a change. God damn leaking batterys. What a pain in the A*S this was this weekend.
Cruise-In V Veteran
Shirl
SDRE
Shirl
SDRE
This HELPS a bunch. This HAS TO BE the problem. Your description really helps as I wasn't looking for the 90 degree peice on the passenger side. I will look again and see if I can see it. It has to be back there somewhere EVERYTHING else looks good as far as I can see and the fact that the vacuum is supplied by the manifold makes perfect sense and after my "test" of sucking on the main connection under the dash.....it sort of confirms it. Back to work THANK YOU everyone for the continued help.........
Bill, I will check back. If you can get a pic that would be great...thank you.....
Keith
Received 3,812 Likes
Shirl
Keith
Keith
