Rear Spindle...
Old 07-22-2004, 01:54 PM
Derrick
Derrick's Avatar
Default Rear Spindle...
How many of you have ever pulled a rear spindle out with a slidehammer axle puller? Is this safe? I'm asking because this puller is ineffective at pulling a spindle out...so far. Thanks.
-Derrick
Old 07-22-2004, 02:35 PM
GTR1999
GTR1999's Avatar
Received 2,587 Likes on 1,326 Posts
I press them out on a 20 ton press. I've heard of large slide hammers doing the job but haven't used one myself.
I think Dalannex made one up,hopefully Justin sees this post and replies.
Gary
Old 07-22-2004, 02:38 PM
75 Hot One
75 Hot One's Avatar
I would think you'd be pounding there for a long time. I've used a knocker (similar to the rear shock knocker) and a small sledge hammer. That worked pretty well.
Old 07-22-2004, 03:24 PM
Derrick
Derrick's Avatar
A knocker? Is that available to rent at AutoZone? Oh, before I forget, do I need to detach the control arm and take the assembly with me to a shop in order to have the bearings pressed in?
Old 07-22-2004, 03:31 PM
stpman
stpman's Avatar
Check out this link for what is involved
http://www.montygwilliams.com/rearbearings.html
Steve
Old 07-22-2004, 03:36 PM
Twin_Turbo
Twin_Turbo's Avatar
Do it right, the spindle ends are very soft, you will deform the threads in no time. I've seen many good spindles become useless because someone hamemred on the end. Get a press or have someone with a press press them out.
Old 07-22-2004, 03:56 PM
NHvette
NHvette's Avatar
You can unbolt the bearing carrier while leaving the trailing arm
bolted to the frame.
-get halfshaft out - then H/S flange that bolt to inside of spindle.
-remove emergency brake parts ... then 4 nuts hidden by Ebrake shoes.
-separate and slide bearing assembly from T/A studs.
I have simplified the whole thing here - but basic steps are there.
Old 07-22-2004, 04:19 PM
75 Hot One
75 Hot One's Avatar
You can buy a knocker at Eckler's and other Corvette parts stores. As I recall, it bottoms on the lip at the bottom of the threaded portion so it doesn't damage the threads. You don't need to detach control arms if you have the right tools. You can do it on the car.
You don't need to go to a shop to press on the bearings if you have the tools to do the job on the car.
Again, various parts stores sell the tools. I got mine from International Axle in Minnesota- excellent quality. They also sell forged low alloy spindles if you decide to upgrade. The tools were a couple of hundred bucks but a good investment.
Old 07-22-2004, 06:03 PM
dman535
dman535's Avatar
Just use horspower like I did:
Old 07-22-2004, 08:37 PM
75 Hot One
75 Hot One's Avatar
Quote: Just use horspower like I did:
Very impressive dman 535. Can you describe under what circumstances the deed took place. What horsepower are you running? What size tires?
Old 07-22-2004, 11:43 PM
dman535
dman535's Avatar
245/60/15 - With a LT-1 spec'ed out 355 and a wicked shifting 700r4. That broke as I was trying to launch the car. It was pretty weird as that one is the passenger side and the driver's side looked mint. Must have just been one to many hits to the spindle.
To Rear Spindle...
Quick Reply: Rear Spindle...
